Results 1 to 20 of 20
    Aug 2017
    Greensboro Pa
    Default What's the going price for an alignment on 2017 RT?
    Hi Everyone
    What is the going price for an alignment on a 2017 RT?
    I had an estimate of $600.00 and went for a $320.00 dealer, then when I got there, it was bumped to $420.00. Prices are going out the roof.
    Thanks Rich
    Last edited by Peter Aawen; 05-12-2023 at 07:18 PM. Reason: Expanded title to briefly ask the question... ;-)
    Nov 2018
    Waynesboro, PA
    Call around usually about 150. There will be a Spyder Rally in Zaneville ohio june 14 - 18th http://www.valueaccessories.net/SEOhioSpyderRyde.htm You should be able to get a deal on a laser alignment there.
    My Spyder
    2012 RTL , Brown
    Apr 2019
    Clinton, MS
    Dammmmmmmmmmmmm, does that alignment come with a side of hot blonde?
    2019 RTL Phoenix Orange
    Oct 2020
    Arizona
    Is it darting around on the road? RU a new spyder rider? If so maybe it is you and not the machine. Out of the open road you need to just guide it along and not try to steer it! If you need to correct a little to the left, then put a little pressure forward on the right handle bar end. And the reverse to the other direction.
    Oct 2020
    Arizona
    I think this was the service writer!
    Jun 2016
    Harrington, Australia
    Quote Originally Posted by Snoking1127 View Post
    Sure, but it never hurts to make sure your alignment is good in the first place, Snoking, otherwise all those tips won’t make a difference. However, that alignment price is enough to baulk at
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Let's keep it family friendly.
    Sep 2016
    Chillicothe, Oh.
    We are. That's my kid sister and her new work truck. She's a roofer
    2015 RT , Black
    Default $$$$$$ alignment
    Did they do a " LAZER " alignment (dealers generally don't have the equipment - plus BRP doesn't use that method) .... I got mine done by the "Netzley's" at SpyderQuest in NY cost $125.00 2 years ago .... Mike
    Sep 2015
    Chilliwack, BC. Canada
    I don’t know about that Mike....my dealer has the Rolo. They checked mine, at my request, a year after I bought it and all was well. I wasn’t experiencing any problem, just wanted confirmation.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Apr 2019
    Clinton, MS
    I think several dealers have the right equipment, but do they have a tech that knows how to use it?
    Quote Originally Posted by bigbadbrucie View Post
    I did use the TERM " generally " .... On the rolo website they list all the DEALERS that have it ..... doesn't look like many to me ....................Mike
    Active Member tntnj's Avatar
    Sep 2015
    JerseyShore
    I had my 2017 F3 LTD done 3 years ago and it was only $150.00 then.
    2017 F3 LTD (SOLD)
    2017 HD Freewheeler (SOLD)
    2021 RT Base Upper and lower adjustable deflectors , Top case, Signature and lower lights, Baja Ron Bar, Back rest,Fobo TPMS, Garmin 396 , LED Fender lights, Rear LED turn and brake lights, Rear Brake light flasher, Rear Saddle bag LED lights, Battery tender, Lamonster Handle Bar Riser.
    Active Member Blake33's Avatar
    Mar 2013
    Lakes Region of NH
    Quote Originally Posted by dolittle View Post
    Hi Everyone
    Thanks Rich
    Rich - I just had my 2018 Spyder RT Ltd aligned by my local BRP/Spyder dealership. The cost was $178.50.
    2018 RT Ltd.
    2018 RT Ltd , Oxford Blue/Chrome
    Very Active Member Isopedella's Avatar
    Feb 2022
    New Zealand
    Apples with apples.
    For instance what type of alignment are you asking and or reporting about.
    2017 F3 Ltd
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    Blake33 was this a laser alignment ? i just got quoted $650 for laser alignment. The only adjustable items appear to be toe and the steering sensor. I was told there is no camber adjustment at all. They wanted to charge me $175 to diagnose first !!! so $825 And I was quoted $400 3 weeks ago, no additional fees...
    BTW this is Mountain Motorsports in Marietta GA.
    If someone could look up the parts diagram and look to see if the upper and lower arms could be adjusted via shims on the arms where they mount to the frame, I would appreciate it. Shims would be a very inexpensive way to add or remove camber as the fronts are no driven wheels.
    Nov 2022
    Georgia USA
    Looks like the 2019 RTL front A arms both upper and lower terminate in 2 round bushings. I will have to look further into the diagram for the frame to see if the pivot/attachment bolts are in a bracket bolted to the frame.. Would it be possible to use offset camber bolts to achieve that perfect alignment ? Might require new bushings on the A arms too. Are new bushings available from Can Am separate from the A Arm or aftermarket ones available? What material are they made of ? Mounting brackets for the A arm pivot bolts?
    Apr 2019
    PA
    You’re in Greensboro, either shoot over to the Ohio south rally June 13th or so and Netzley do it or shoot straight up to Netzley in NY. They will do a laser alignment for $100.
    Nov 2022
    Georgia USA
    Got the Spyder laser aligned today at Extreme Propulsion in Cartersville GA. Very nice folks to deal with. They do have a Spyder specialist who has done many TLT alignments . They can also do Slingshots if you have one ( I have a 2019 SLR too )
    Spyder rides better / is less twitchy now. Tech said it was def toed out :-(
    If I need to go further, what should i do in terms of the 1. tires (stock Kendas on there now ) 2. shocks ( stock ones on there now )
    Hopefully i dont need to but JIC :-)
    Very Active Member rjinaz86323's Avatar
    Mar 2021
    Arizona high country
    I blew a tire this morning hitting a pot hole. I bought a new tire and RideNow in Peoria charged me $129 for a laser alignment.
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
