Results 1 to 8 of 8
    Active Member Mike0123's Avatar
    May 2020
    Rhode Island
    Default Help please!!!! Where's the pin for brake res? 2021 RTL Oil change
    So I am going out of my mind looking for the pin thats supposed to be holding the brake fluid reservoir on. I see a tab back there that looks like I hay need to pry it away then slip the reservoir up ... is that what i am looking for on this model?
    I' appreciate any advice... Dudley is up on blocks with no oil.. need to wrap this up!
    TIA as always
    Last edited by Peter Aawen; 05-12-2023 at 07:46 PM. Reason: Expanded title to briefly ask the question... ;-)
    2021 RT Limited in Marsala Red & chrome (9/20)
    2006 Yamaha Royal Star Venture - Black Cherry
    2003 Suzuki Volusia - Black w/ Gold
    1973 Honda CL350 - Hawaiian Blue
    2021 Limited , MArsala Red & Chrome
    Active Member tntnj's Avatar
    Sep 2015
    JerseyShore
    I have a 2021 RT base and I was able to remove the cover for the oil filter and oil filter with removing the brake reservoir. I went to the right and behind the reservoir.
    2017 F3 LTD (SOLD)
    2017 HD Freewheeler (SOLD)
    2021 RT Base Upper and lower adjustable deflectors , Top case, Signature and lower lights, Baja Ron Bar, Back rest,Fobo TPMS, Garmin 396 , LED Fender lights, Rear LED turn and brake lights, Rear Brake light flasher, Rear Saddle bag LED lights, Battery tender, Lamonster Handle Bar Riser.
    Active Member Tourer's Avatar
    Jul 2022
    North Carolina
    I never saw a pin on my 2015 F3S when I did the first oil change. I secured the reservoir with a wire tie.
    2015 F3S SE6
    May 2020
    Rhode Island
    Quote Originally Posted by tntnj View Post
    OK. OK
    I see that. I’m trying that. Thank you so much.
    Mar 2021
    Maryland
    Quote Originally Posted by Tourer View Post
    Ditto for my base F3
    2020 F3 SE6
    2020 F3 , Black
    Dec 2020
    Hartwell, Ga
    It looks like a small black tube, honestly that's what it is. You need some needle nose pliers to get in there to remove it.
    Also, I didn't put it back in and have never had an issue with the reservoir coming off on its own.
    Clinton, MS
    At some point in the 2020 + RT models where the brake fluid reservoir was moved forward over the oil filter they switched from a plastic tube holding the reservoir to its mount to a metal pin. The metal pin is easier to manipulate. If yours uses the plastic tube I suggest getting a longer piece, about 6", cutting the end at an angle, and removing and reinstalling it will be a breeze.
    2019 RTL Phoenix Orange
    May 2020
    Rhode Island
    Alrighty. Thank you all. I got everything done. I was actually able to reach to the right of the reservoir and down to the oil filter housing. Worked great. Never had to move the darn thing at all.
