Should my 2020 RTL have a Ride Firmness Switch?
Should the 2020 RTL have a switch to adjust the firmness of the air suspension? If so, where? Or is it fully automatic and out of the rider's control? TIA.
Chip
2020 RTL
"Stella by Starlight"
Reason: Expanded title to briefly ask the question... ;-)
There is not one for the 2020+ models, it is automatic.
Make that 2018 + models and not sure about the 2017's
Thanks EdMat, I didn't know that.
Thanks
Thanks to EdMat & K80Shooter for setting me straight.
Chip
2020 RTL
Chip
2020 RTL
Chipveres, just another aside - the auto adjust on your airbag has the primary aim of ensuring your RT is level, as the ‘20+ models have LED Lighting which can blind oncoming drivers if aimed too high. You don’t have “air suspension” per se, but simply a shock and a separate air bag. The air bag does however sit between the shock and the seat, and does contribute to a better riding experience.
Pete
Harrington, Australia
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
My 17 Spyder RTL has the air bag adjustable switch on it. I can adjust the softness or hardness of the airbag with the switch on the front console. It stays wherever I leave it at.
2017 RTL Asphalt Grey Metallic Chrome
Thanks for the confirmation that it is the 2018 + models that no longer have the manual adjustment. Thought it occured at the same time as the new dash layout but was not positive.
