Results 1 to 11 of 11
    Mar 2021
    Haven, Ks
    Default 2022 Comfort Seat isn't! Any more comfortable suggestions?
    I have a 2022 Sea to Sky which came with the heated comfort seat as standard. I previously had a 2019 RTL that I had an Ultimate seat installed. I could do 1000 mile days with the 2019. Took my first long ride on the 2022 this past week, 1400 miles in five days. From my rears perspective the Comfort seat is anything but comfortable. Have any of your tried alternatives. I see that Ultimate makes a seat for the 2020 and up models but their web site makes it appear to be a one-piece seat and the factory seat is two-piece. Anyway, do any of you have suggestions for a more comfortable ride?
    Last edited by Peter Aawen; 05-11-2023 at 07:39 PM. Reason: Expanded title to briefly ask the question... ;-)
    Bartender
    2022 Spyder Sea to Sky
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    I'm saving my pennies for a Corbin seat.
    I find the sea 2 sky no better than the stock RT-l
    Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    I'm either getting a Corbin or a Russell-DayLong.
    2021 RT Base - Petrol Blue
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    Personally I'd go with Russel or Lamm. I've had hit or miss with Corbin - loved it on an ST1100, hated it on a CB750. And then there's the cost and weight. Corbin seats are HEAVY, so unless you opt for the gas door, you'll need a stronger seat strut or some kind of prop rod.
    My brother is getting a Russel done for his Goldwing. Admittedly, he's getting lower end materials - vinyl and no custom stitching or anything, but still with shipping his seat out there, he's paying around $1100. About the same (or less depending on options) than a corbin. Russel guarantees you'll like it, and will even make one free set of adjustments.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Active Member Bob L's Avatar
    Oct 2014
    Massachusetts
    I got a Corbin for my 2022 RT this spring. Had one on my 2014 (and on a Triumph). Been very pleased. They are "stiff" and break in over time.
    Good luck!
    Bob
    Bob L.
    Worcester County Massachusetts
    www.rk-mass2.org
    Dec 2015
    Oakley Utah
    You haven't said what you find uncomfortable about the stock seat, so who's to say what will work best for you?
    BTW, there is already a wealth of information on this topic. In addition to expensive custom seats, there are ways to make your stock seat more comfortable, depending on the issue you're having. MotorcycleDave sells a very cost-effective solution, I think. https://www.motorcycledave.com/
    https://www.spyderlovers.com/forums/...archid=3897207
    2014 RTL Platinum
    Active Member Two2Three's Avatar
    Mar 2023
    Missouri
    I put a Corbin on my 2022RTL. Huge improvement, a little wider than stock, etc. I've always upgraded to Corbin seats so I'm used to them.
    I considered the Russel but didn't want to ship the seat off to be modified. This way I can just put the stock seat back if I ever sell the Spyder.
    Your solution may be as simple as an Air Hawk pad. Last time I looked, under a $100.
    Sep 2021
    New York
    I have a 2019 RTL and just switched out the stock seat for an Ultimate. Only rode it once for maybe 15 miles but love it. So much more supportive. The slightly higher profile works really well because I can easily rest my feet on the footboard and hit the brake. My hips are way more supported and I can comfortably put my feet on the highway pegs. The stock seat pushed me to forward and into the dip behind the storage compartment. Anyway, seems you know about the feel of the 2019 model. Can't speak for other seats but super pleased with the Ultimate seat so far.
    Sep 2022
    Central Florida
    I too was not impressed with my 2022 RTL seat. I opted for an Air Hawk pad for a less expensive alternative. Very little air in it but boy, what a difference.
    May 2021
    Upstate NY State
    I've decided to get the Corbin 1 piece seat. I'm going to order it today or tomorrow.
