Results 1 to 8 of 8
    Sep 2019
    illinois
    Default Fuel Average Reset, Now Gaining too Much MPG - any ideas?
    I cleared off my Fuel Average to zero, as expected. Then as putting in the miles it was climbing slowly as it has done before, as expected. Now it's going up and beyond 42+ mpg, NO WAY! Last year holding 38+ mpg., as expected the way I drive, mostly county roads, very little 60 mph and not on highways much at all. I reset twice now doing the same thing. Fuel gauge/mileage seems to be correct after about 70-80 miles, as it always has been. Any idea what could cause this?
    Last edited by Peter Aawen; 05-08-2023 at 03:04 PM. Reason: Expanded title to briefly ask the question... ;-)
    Apr 2019
    Clinton, MS
    Year, model and mileage would help get you an answer.
    2019 RTL Phoenix Orange
    Sep 2019
    illinois
    Sorry about that! Ryker Rally is a 2019 with about 13,900 miles.
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    I'm not surprised. The engine is broken in and you keep the rpms low by staying off the highway. I get mid 30's and I drive it like I stole it.....sometimes.
    Dec 2022
    Florida - Wimauma
    Got an education from this. You re-set the fuel mileage?
    Did not know you could. Time time to dig out the book and learn how.
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    I believe the mileage calculation is way off, and moreso right after a reset. It is a running average from the last reset. If reset just before very gentle operation, it will be high. If reset just before accelerating up a hill, it will show low. After about 200 miles it will average out closer to real, but in my experience always high. It was that way on my '86 SEi, my '08 SX4, daughter's '12 SX4, wife's '17 Equinox, and our '21 RTL.
    "Love 'em all.... Let GOD sort 'em out!"
    2021 RTL Dark Chalk Metallic with comfort seat
    1978 GL1000 w/'75 engine show bike
    1976 RD400c
    Active Member linguine's Avatar
    Feb 2023
    AZ
    Quote Originally Posted by pidjones View Post
    I agree. 4 fillups during our trip [read that as 2 up] from Phoenix to Kanab Utah, then to Zion, then to Page, AZ, then home::> EACH leg showed us at 45+mpg. This is for 65 mph for very long stretches.
    I actually was going to post about this, but this thread just came into view.
    The fixed ODO with grand mpg shows 35+ mpg now. What to believe?
    Yes, I read all the threads, etc about how to fill up, and then calculating by one's self from there. I find the fillup to vary by ~0.4 gal. That's enough variability right there for me to suspect hand calculations as well.
    I'll assume the gas tank gauge sends a "filled" signal to the master GPU, and the calculations are based off the actual wheel-to-ground travel [rpm's, wheel circumference, etc etc].
    Maybe that assumption is even off base.
    Ride safe; shiny side up, greasy side down.
    best,
    linguine
    2020 RT Limited , Chalk Gray
    Active Member DickB's Avatar
    Jun 2021
    FL
    Quote Originally Posted by linguine View Post
    Unfortunately due to the Ryker's gas tank shape, the sending unit sends a "full" signal at anything over about 2/3 full. So the ECU can't tell the difference between mostly full and full full.
    Fuel injected ECUs determine fuel used by how long the injectors are firing. This duration varies depending upon engine speed, load, and whatnot. Since the capacity of the injectors and fuel pressure is known, the amount of fuel squinted through them can be determined by how long each injector is energized.
