Has anyone had any exposure to the 7Jurock windshield? I like the flip design but not sure if it's going to make a difference from the stock windshield I have on my 21 RT.
Yes the flip does help. Had a couple on previous F3T, one wider for winter use. As with any plastic windshield, perhaps with exception of F4, they do, over time, get micro scratches from cleaning, no matter how careful you are. I am considering one for my recently purchased '22 RT to see if a shorter one will allow me to look over. I can not with the current OEM although it does a good job other than having to look through it.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
If you type '7Jurock' into the Search field up toward the Top Right of the Page, then click on the 'Search Titles Only' field before submitting the search, you'll get about 2 pages of results back, and from the thorough cursory glance that I just gave them, it certainly looks like most are pretty happy with them, but there's a lot more detail in there that's probably worth you reading!
After reading the reviews of many, including here, I have decided it's the right choice and will purchase it as soon as I get a little extra cash. Thank you all for your feedback.
So which height are you getting and why? It seems to me that most people are going smaller but, I want to go with the tallest one.
I'm thinking 25". I'm 5' 10" (yes Peteoz, I'm short to you, but most are) and think anything taller than 25" would be too much. I like looking over the shield but still like the wind protection.
I bought one used here on the forum with the flip. I installed it, rode with it for a day, and then uninstalled it that night. It had such bad distortion when looking down at the road through the flip I just couldn't stand it. It actually gave me motion sickness. I just couldn't do that to someone else so I threw it in the trash. I do not recommend them at all.
Peter Pan has struck again!
The 7 Jurock can be ordered with or with/out the flip, tinted or not, even made to order.
I bought the 25" with light tint and the flip. I like it because it's wider than OEM and the flip distortion of viewing doesn't bother me as much now as when I first installed it. You won't find a better price for a windshield anywhere else that I could find and they do have discounts available sometimes. I would buy again if needed. Bill
Frogman Dave's "Signal Button" If in Doubt, Don't Do It!
My new 7Jurock arrives tomorrow for my 2022 RT S2S. Removed my OEM shield today in preparation. My 2022 shield doesn't use grommets/steel sleeves for attachment. Will the 7Jurock arrive with the same screw hole sizes as the OEM ?? Thanks
2022 RT Sea To Sky
I just put a 22" 7jurock on my F3t, it is my 3rd shield from them, I like to look through the shield. For the price they are excellent and they will custom make them to your specifications.
The flip is bent material which is always going to have some distortion. You are not supposed to look through the flip but over it.
Mine did. At least compared to the Route 129 it replaced.
I'm 6'3" tall and bought the 27"/flip/light tint shield with OEM vent holes cut in. The OEM is 25" and when fully extended, it is at chin level. I prefer to look over the shield, not through it. You sit a bit taller on the RT models.
2022 RT Sea To Sky
2016 RT-S Pearl White
BRP Driver Backrest
Lamonster Spyderdock, (2) Spydercuffs
Magic Mirror w/Doc Humphreys tethers
(2) Rokform phone mounts
FOBO
SpyderPops Bumpskid,missing belt guard,Rear strobe LEDs
Lamonster LED headlights & foglights
Spyder Pockets
LED front fender kit -running & turn signals
Custom Back off mudflap
Vinyl nameplate & 1330 triple decals by New Image Signs
Custom RLS exhaust
Hogtunes speakers 5 1/4 front and back
Memphis Powersports Amp
Her name is "Purl"
Let us know how it works out. The 27"/flip/light tint shield with OEM vent holes cut in is the one that I want for mine.
HeliBars Handlebars
Kenda Kanine rear.
I don't remember the height, but I replaced a stock Tall Boy which sent the wind directly to my forehead. All the other aftermarket pieces require their mounting brackets also, so I tried this one. I'm 5' 8" and look over the top. The width and the flip work great for me. Can't remember the young lady's name at 7Jurock, but she is awesome and will help get you what you need.
I never got around to answering you K80. I ended up buying the 27" because with the new Corbin seat, I sit a bit higher and the OEM 25" windshield is too low now. With the 27", I can still see over it.
Thanks Quickdraw! I have decided to go with the 27" also.
