What is the latest & greatest 2014 RT Rear Tire?
What is the latest and greatest rear tire for the RT? I have not been riding as much as I used to so I am out of the game so to speak. I am starting to ride more this year and it is time for a new rear tire. I was just wondering what people are using nowadays. I know they improved the stock Kenda a bit, but from what I read, it still does not last. I like the Kendas they used for the fronts and still have plenty of tread left (I have not quite 20k on the spyder). Thanks.
SpyderLovers Ambassador
Rear Tire
.... The Spyder Forum talk on a Rear Tire is a Vredstein Quatrac :Size 205/60-15 or 205/65-15.
General Altimax RT43 or a Michelin XM2+ .
I hope this helps you find a better Rear Tire.
Stay Healthy and Be Safe. ....
ENJOY YOUR LIFE WITH A SPYDER
Thanks!!!
Vredstein Quatrac :Size 205/60-15 or 205/65-15 This is what I'm using on my 2014. it had a Kumho on it when I got it, but after a year I replaced it and the front Kendas with the VrVredstein Quatracs.
2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
SpyderLovers Sponsor
If you go with the General Altimax. Consider the 215/60/15 tire. It's closer to the OEM width than the Vredestein, giving you a bit more meat on the ground. And though I would never run a tire on the Spyder for looks, I think the wider tire does look better. Both the Altimax and Vredestein Quatrac are great rear tires. I wish the Vredestein would come in the 215 size.
Looks like the Quatrac may/is no longer being made. I don't see it listed on Vredestein's website. It is out of stock on Tire Rack as well (Update: Looks like Tire Rack may have them. Looked earlier and said OOS, not IS). May need to go with the Altimax.
Nope .... the Quatrac 5 was replaced by the QUATRAC .... ANOTHER CHOICE IF YOU LIKE 215 size is the RIKEN Raptor ..... I have one because it was $20.00 less and the rating was ONLY slightly lower then the others ..... and I like it .... Mike
Nope .... the Quatrac 5 was replaced by the QUATRAC .... ANOTHER CHOICE IF YOU LIKE 215 size is the RIKEN Raptor ..... I have one because it was $20.00 less and the rating was slightly lower then the others ..... and I like it .... Mike
https://www.vredestein.com/car-suv-tires/products/
Quatrac is not on there, the 5 and the Pro is, but not the Quatrac. Guess they don't update their website very often then.
Originally Posted by Hawk
well TIRE RACK has the QUATRAC ..... they are running low on the Q-5 .... but that's because they arn't making them anymore !!!!! .....Mike
We have installed MANY Yokohama ADVAN tires for the rear of Spyders. Much prefer them over the General or Vredestein because of the much better traction both wet and dry. Its a quality tire and Made in USA.
are you sticking with the 225 width.
Yokohama we use 205/55R15. Its within 1/8 inch of same width as OEM tire. You have to compare actual dimensions of the various tires, not the nominal size number. Yoko sports tires tend to run wide, Kendas are narrow.
Could you post a link, please? When I search Yokohama's site I only get the AVID model in the Spyder sizes.
2021 Spyder RT Limited (Sea-To-Sky)
2022 Ryker Rally
https://www.tirerack.com/tires/tires...num=055VR5V701
Thanks for the link, I’m always looking for the best tire. I admit I don’t know much about tires so I rely on information from members more educated on the subject than me, but using tire racks comparison charts the Quatrac ranks higher in every category than the Advan so for now think I’ll stick with the Quatracs until something better comes along.
2022 Ryker Rally
I love folks who are willing to do a little research, I have said what you just said but got pushback ..... Mike
You cannot compare the ratings at tire rack between those two tires. The ADVAN is in Ultra Performance Summer Tire category and the Quatracs is a touring all season. The ratings can only be compared with tires in the same category. IE a performance tire with lower traction rating can still have far better traction than a touring tire with a slightly higher one.
I can tell you from first hand experience that the ADVAN has MUCH better traction than the Quatracs when used on the Spyder. Much better than the OEM Kenda too and still manages to last far longer.
What model Advan was that?
HI Hawk,
I have a 2014 RTS-SE-SE6 spyder also, I am running General Altimax RT43 on the rear(Tire size :215/60R15) The first General was installed at 5,824 Miles, and the second General was installed @ 24,553 miles. I am running at 26 psi. The current mileage on my spyder is 30,000.00 +. I haven't had problems with the General tires.
Here are the ratings: Wet 8.6 Excellent( 8.6 Hydroplaning Resistance 8.6 Wet Traction)
Dry 8.8 Excellent ( 8.7 Corner Stability, 9.0 Dry Traction, 8.7 Steering Response)
Comfort 8.6 Excellent
Treadwear: 8.4 Good
I hope the above info helps.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
