Results 1 to 23 of 23
    Very Active Member tofriendscreek's Avatar
    North Central Arkansas
    Default Trunk Lid Dropping - any adjustment or fix?
    Is there a way to adjust something/somewhere which would keep the trunk/top case open on a 22 F3 Limited?
    2022 Plasma Red, F3 Limited, Special Series
    Mar 2023
    Phillipsburg, NJ
    I took mine into the dealership and they were able to fix it under warranty. Had to replace some parts that would hold the lid open.
    Rob
    2020 Can-Am Ryker 600
    2021 Can-Am Spyder F3 Limited
    2020 600 , Can Am White Design
    Jan 2021
    northeast pa.
    its suposed to stay up, till you close it , if not, take to dealer to fix under warrenty..
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
    Feb 2020
    illinois
    a small rubber door stopper placed between front of lid to rear seat works- especially on windy days or on incline. less than two bucks for two.
    Mar 2019
    Ruidoso Downs, New Mexico
    I have the same issue but mine started with the addition of the rack. It is just heavy enough that the lid won't stay up. A stick solved the problem on my trip to AK. I don't think there is anything wrong, it is just a weak (spring?).
    2020 F3L; gone but not forgotten are all the good miles!
    Dec 2015
    Oakley Utah
    Plenty of threads on d-i-y fixes for this common issue...search "trunk strut"
    2014 RTL Platinum
    Active Member GRHorst's Avatar
    Mar 2022
    PA
    "started with the addition of the rack"
    This was the case for me also. I need to look for a fix. I would think there would be a gas strut that could be added to solve this issue?
    _________________________________
    GR Horst - Reading, Pennsylvania, U.S.A.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by GRHorst View Post
    See above
    2014 RTL Platinum
    Danbury Connecticut
    I did this fix. It adds a helper spring to the strut for about $5.
    https://www.spyderlovers.com/forums/...=1#post1645384
    IBA #47122
    2020 RT Limited Asphalt Grey
    Durham,Maine
    Looking at your avatar pic you have something on top of your case, the strut on that cover is not heavy enough to lift that much weight, you will have to find a way to prop it up or get a heavier strut, I found one for my seat from McmasterCarr, some say that they have not had much luck for that trunk strut, so you may want to call them to see if such a dog can be found!
    2012 RTL , Pearl
    Apr 2016
    Albany NY
    Qty (1) Replaces Can-AM 708303630... https://www.amazon.com/dp/B0BT9B9RNQ...p_mob_ap_share
    This is a heavier duty one that works with a Luggage rack on it.
    Active Member WingmanRT's Avatar
    United States
    Slingmods has a heavier duty replacement. Here's the video on replacing. I did the trick above of putting a heavy duty spring on teh strut to support it. Not as good, but waaaaay cheaper.
    Paul "Wingman" Metheney
    2020 Can-Am Spyder RT Limited
    2020 RTL , Red
    We have racks on both our f3l's. No problem with trunk staying up. Sounds like it may be a weak strut. That is what I would check first.
    Mar 2013
    Marion, Arkansas
    Well my 2017 F3 Limited doesn't have a strut. When I lift my trunk lid it snaps in place and won't fall until you push the orange release lever. Are we talking about F3's or RT's here.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Jul 2021
    MN
    Quote Originally Posted by Ex-Rocket View Post
    F3. My 21 doesn't stay up either. They have a gas strut. But I suppose the luggage rack on mine is part of the problem. I cut a piece of wood to stick in the hinge to keep it up.
    Mar 2019
    There must have been several iterations of the trunk: my 2020 F3L has neither a strut nor an 'orange release lever.' The hold position is built into the hinge as near as I can tell. A stick solves the problem.
    Active Member linguine's Avatar
    Feb 2023
    AZ
    Quote Originally Posted by WingmanRT View Post
    That video does not show the orientation of the mounting post for the 2020 RTLimited trunk.It is not that easy...
    Ride safe; shiny side up, greasy side down.
    best,
    linguine
    2020 RT Limited , Chalk Gray
    Jan 2021
    Oklahoma City
    Quote Originally Posted by linguine View Post
    The hardest part of replacing the strut for me was removing the spring clip off the bottom post mount, otherwise it was straight forward, quick and relatively easy. Best of all the new strut works way better than the OEM ever did.
    2021 Spyder RT Limited (Sea-To-Sky)
    2022 Ryker Rally
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    Quote Originally Posted by Adventurer View Post
    Ditto what Adventurer said ... it really was very easy after removing the spring clip off the bottom post mount with a small screwdriver.
    Love my Spyders
    2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
    2014 RTS Circuit Yellow purchased 3/2/2018
    2020 RTL Petrol Blue purchased 1/27/2023
    Girls on Spyders #3195
    No more 2 wheels
    2020 RTL , Lamonster floor board riser Petrol Blue
    Mar 2019
    Default Aha! Hidden struts!
    mea culpa! I should have realized that the struts everyone was talking about were hidden behind the passenger back rest. Now I have my job lined up for today....
    Fast forward to this pm. I pulled the backrest and to my surprise, there is one strut that is held in place with a bracket. I can't see any way to remove the top of the strut without removing the top of the box but that is just two bolts. Now to see if I can find a replacement strut. The video from SlingMods is evidently just for the RTL as the F3L, mine at least, is different. I'll see if SlingMods strut will work on mine.
    Mar 2022
    PA
    Quote Originally Posted by TIMMB View Post
    I ordered this replacement strut and was able to install it yesterday. It fit my F3L just fine and does the job perfectly. Installation is not hard as long as you don't loose the U band. I lost it but the U-band off the original strut worked fine. (Someday I'll probably find it and wonder what it is and where it came from)
    Feb 2020
    illinois
    On the newer Rt and f3l ( 2020 and newer) the truck lid strut is not robust to continually work in keeping the lid open and especially if parked on uphill or on windy conditions. Both my 2020 RTL and 2022 F3L Limited worked for a few months then lost it's functional capability. I now use a small rubber door stop wedged between lid and passenger seat back. Have on order a better built strut rod to replace oem.
    Vermont
    My new 2023 F3 LTD special the lid stays open, and it has a luggage rack on it.
    I have not had any problems with the lid.
    I have had my new 2023 F3 LTD Special for almost a month now.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
