Results 1 to 5 of 5
    Aug 2017
    Binghamton NY
    Default Anyone built an RT622 Trailer Kick stand?
    Has anybody built a kick stand for your Can Am Trailer?
    I need something simple to support the tong. Using a jack stand now but a simple trailer kick stand would be nice.
    If not building one where can I buy one?
    Thanks
    Jun 2016
    indpls in
    leaders rpm shop free delivery $120
    Sep 2021
    PA
    A bicycle kickstand may do the trick
    2018 RT Limited
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Nov 2013
    Central Texas
    Quote Originally Posted by bigcontender View Post
    Thanks
    If you go with the CanAm stand, you should install a trailer hitch pin to keep it up on the tongue when travelling. The dinky spring thingy that comes with the stand doesn't hold it up. I found this out on a road trip when I stopped for gas, the stand was dragging on the pavement, and I had to secure it with a bungee cord. Drill a hole through the stand and tongue with the stand in the up position. Make sure to drill the hole 1/16 in larger than the diameter of the pin for easy in/out. This fix solved my problem, and hitch pins are cheap. This should work for you.
    https://www.amazon.com/Buyers-Hitch-...xpY2s9dHJ1ZQ==
