Found brake fluid, may be a caliper leaking? Anyone replaced one? Cost?
Was looking to see where the caliper bleeders were, thinking of putting speed bleeders on then changing the fluid when I found what looks like brake fluid on the bottom of the caliper! Has anyone had this problem before? In the next couple of days, I will get it up in the air and see where it's coming from. It is a 2020 RTL and only got about 8050 miles on it. If anyone has replaced a caliper, what does one cost.? I got the extra warranty, but they will what to look at it and then keep it, and they do leave things outside. and that's not going to happen. Thanks
Reason: Expanded title to briefly ask the question... ;-)
Check to see if the lines going to the brakes are in the guides. If they did not put the brake lines in the guides when it was assembled, the lines would rub every time the steering is turned. Eventually the lines rub through and leak.
Forum
RT Shop Talk
