Results 1 to 14 of 14
    Apr 2020
    Edgerton,WI
    Cool Dot3 vs Dot 4 brake fluid.
    Your Spyder probably uses DOT 4 brake fluid with a maintenance schedule of every 2 years……Dot 4 has a tendency to absorb more moisture from the atmosphere than Dot 3 fluid, BUT….. Dot 4 has a higher boiling point with less seal swell than Dot 3.
    My Spyder only has 11k on it and I found the fluid very dark instead of the amber color of new fluid……… just saying…….. probably good not to overlook the required maintenance.
    2019 F3L , Covid Blue
    Active Member Tourer's Avatar
    Jul 2022
    North Carolina
    If you haven’t performed this maintenance yet, would recommend getting speed bleeders. Makes the job super easy. Buy the bag and hose from them also. Took me 45 minutes and didn’t spill a drop of fluid.
    2015 F3S SE6
    Sep 2016
    Chillicothe, Oh.
    Quote Originally Posted by Tourer View Post
    2015 RT , Black
    Apr 2019
    Florida Swamp
    + 1 on the speed bleeders.
    That, along with a vacuum pump on a catch jar, makes it a 10 minutes job.
    Took longer to put the old brake fluid back in the container to be disposed of than it took to change the fluid.
    2019 F3-S , Black & Silver
    Sep 2017
    Durham,Maine
    X3 They are a great tool in your box of tricks, if you choose to install them!!!!
    2012 RTL , Pearl
    Very Active Member Bensonoid's Avatar
    May 2014
    Benson, NY
    My 4 wheelers require DOT 3 and the spyder DOT 4 so I use this.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Jun 2022
    N.E. Fl
    Our shop has an abundance of DOT 5.1 (NOT 5) so that's what I use...
    2016 F3-T , Blk/Rd
    Apr 2020
    Lebanon ohio
    Where are you getting speed bleeder from and what info do you need to order them I have a couple of projects I can use them on besides my spyder and has any body had problems with them like leaking?? Thanks
    Apr 2019
    Clinton, MS
    Quote Originally Posted by Longtimer View Post
    http://speedbleeder.com/bikechart.htm
    No leakage problems.
    2019 RTL Phoenix Orange
    Thanks for this ..... Do you think these cannot be used on a car / trk ???????....... Why only Mtc's ...... Mike
    Apr 2019
    Clinton, MS
    Mike, click back on their home page and you will find their charts for different type vehicles. Love mine. They will become a standard addon for anything in the future.
    Aug 2019
    southwest oHIo
    Quote Originally Posted by Bensonoid View Post
    Your 4-wheelers might "require" DOT3, but DOT4 will work in them just as well (or better).
    Quote Originally Posted by Jane1330 View Post
    It is good that you know the difference that ".1" makes. DOT5 fluid is silicone-based and is not compatible with DOT3 or DOT4. I think there might be issues with seals, too, you need to ensure that the entire system will work with DOT5. For some reason, they came out with a DOT5.1 that is compatible with DOT3 and DOT4, but has improvements. The (unfortunately) similar name can be rather confusing.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    OK , thanks for that .....I'll check if the Spyder models have the same numbers for my Nissan Versa >... Mike
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    AMAZON.com is where I got mine. Check the chart for right ones!
    2014 RTL bought in 3/20 with only 6,000 mi.
    Came with Garmin 660
    Car tires in 5/20; Elka stage 2 front shocks in 10/21
