Results 1 to 16 of 16
    Very Active Member Isopedella's Avatar
    Feb 2022
    New Zealand
    Default Third peg frame bolt torque?
    So I picked up a third peg.
    Wondering what is the correct torque for that bolt?
    Thinking 8mm - about 22 Nm? - 195 in lbs maybe.
    Oct 2015
    Lynden, WA
    Default Bolt torque specs
    Torque specs for bolts on Can-Am ATV.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Feb 2022
    New Zealand
    Cheers Haze.
    Found YFS 12.9 on the cap screw head.
    That chart suggests up to 40 nm.
    But is that correct for the application there?
    Looked lots of places but cant find the info.
    Feb 2022
    New Zealand
    Think I just found it on page 136,357,007 of the extended book of words.
    19 Nm / 168 in lbs.
    Aug 2020
    Niagara Falls NY
    Just tighten it up.
    Vince F in Niagara Falls
    2022 Spyder F3 Special Edition
    2020 Ryker Rally, sold
    2022 F3S , Stock Lamonster black diamond Monolith Black Satin
    Feb 2022
    New Zealand
    Yep. Seems to be the norm, even in the videos from the experts?
    I like to torque them thanks. Nuts eh?
    19 Nm/168 in lbs. will do just fine.
    Feb 2022
    New Zealand
    Quote Originally Posted by Vincef329 View Post
    Just tighten it up.
    How about this? Just a tad too tight I'm guessing.
    Dec 2013
    Quote Originally Posted by Isopedella View Post
    Just a tad!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Sep 2017
    Durham,Maine
    You got to use your head!
    2012 RTL , Pearl
    Feb 2022
    New Zealand
    Yup you sure do. Up there for thinking.
    Sooo...
    Got 7 jobs for the F3 today.
    I had a few things delivered yesterday.....some goodies...... .
    Check the tyre pressures.
    Fit the third pegs.
    Fit the mirror lock bolts.
    Fit the PedalBox.
    Fill the tank.
    Go for a spin. Should be interesting. Give it a crack as they say.
    Return home safely without needing a new change of underwear and open a cold bottle of substitute brake fluid and reflect on the day.
    Pretty sure if I dont do them in that order one of the earlier mentioned jobs simply wont get done.
    Feb 2022
    New Zealand
    The install went ok. I had to clean out the threads from that yellow stuff. Then lift the arm a bit to re-install the bolt for the hanger. Took a photo where you may make out the mark inside where is should be. I will have to take a snap of the finished job and add to this post tomorrow.
    FWIW I bought from Lamonster
    Stock Caps Third Peg - All F3 Models
    (3RD PEG OPTION: IPS LRG BLK Grippers Pegs)
    LG-1060-1041B
    They are awesome.
    Last edited by Peter Aawen; 03-29-2023 at 01:42 AM. Reason: Fixed attach display ;-)
    Feb 2022
    New Zealand
    Active Member T.P.'s Avatar
    Oct 2016
    APPLE VALLEY, MN
    Just an FYI observation, the 3rd peg you have pictured in your hand is for the other side, not the side pictured.
    This is going to confuse somebody for sure
    T.P.
    Feb 2022
    New Zealand
    Yeah I guess it possible I may confuse some.
    If you care to view the photo above your post - zappoh! I seem to have matched the right peg holders.
    The post and photo you refer to is in fact a question about the bolt and the correct torque.
    I did not want to strip that with over-torquing the bolt - hence the question..
    The bolts appeared to be identical in size, thread and length.
    And if you want to get super Anal about the photo and the captions.
    Its in fact correct........
    "I picked up a third peg.... correct.
    Jun 2011
    Alamogordo, NM
    Just finished my installation of Lamont's 3rd Peg set up.Surprised at the big difference they made in getting both on and off. A definite improvement.
    Another comment on just how professional the entire transaction is in dealing with Lamonster Garage. A true class operation, thanks.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Aug 2007
    Greeneville, TN
    Just tighten it up.
    There it is!
    "Follow the Science" as they say... I like it!
