Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
  1. #26
    Idaho
    Quote Originally Posted by fatboy View Post
    i cut the nine wire plug off found ground got battery found out what wire did what and connected a five wire plug all good
    That is the simplest way to go except you have to change the trailer harness on the bike to 5 wire system. But in this case the OP wants to pull the trailer with both his 2014 and 2022 with totally different bike side harnesses installed! Did you happen to read the two old threads I linked to above? They give a good picture of the frustrations with the trailer and bike harnesses back in the 2010 to 2014 time frame. Wasn't pretty!
    2014 Copper RTS
  2. #27
    Active Member spyderryder53's Avatar
    Jul 2014
    Hanover CT
    Thanks for the info but the 2022 is as it should be and I don't want to mess with that.
    ( that's above my skill set anyway lol )
    I'd rather change the trailer to 4 pin
    or look for a freedom trailer in new england
    2022 marsala red RTL
    AND
    2014 RT S SE-6 COGNAC, 2010 RT 622 TRAILER TIMELESS BLACK
    BRP trailer hitch, Utopia back rest, Baja Ron sway bar , heim links. Elka stage 2 shocks front and rear.
    TricLed fender lights, saddlebag lights and mirror lights. LED headlights and fog lights, Wide vu mirrors.
    spyderpops LED bumpskid ,zippered cargo bag linings, Laser Alignment by Netzleys Tire, Stebal air horn
    stant gas cap,( Dimple oil plugs REMOVED ) JT dash mount.
    (Onboard) Lamonster Garage air compressor and intelliboost charger.
  3. #28
    Jun 2016
    indpls in
    the freedom trailer in no way compares to the 622
  4. #29
    Dec 2013
    Freeby bump, but Please don't forget that you've posted this thread, and to follow the directions in the Sticky to keep it live or mark it Sold once you've found/sorted your trailer harness.
    https://www.spyderlovers.com/forums/...sub-forum-****
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
