Will a 2021 Sea to Sky fit in a 6x10 utility trailer?
Will a 2021 sea to sky fit on a 6x 10 utility trailer?
Reason: Expanded title to briefly ask the question... ;-)
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
6 ft X 10 ft. is fine ....... The important measurement is the Width of the trailer opening .... good luck .... Mike
And don't forget, the stated width of the trailer often doesn't factor in the wheel wells creating a bottleneck in the middle of the trailer. You may be able to back onto the trailer but then most of your weight will be on the back of the trailer and not on the tongue.
Also make sure the trailer loading ramps are long enough so the front end of the Spyder doesn't catch when loading...larryd
Ozzie Ozzie Ozzie
2013 RT Ltd Pearl White
Ryde More, Worry Less!
