Results 1 to 15 of 15
    Dec 2022
    Republic of Korea
    Default Should the HCM filter be replaced?
    My Spyder F3S is an 2018 motorcycle. Should I replace the HCM filter?
    my total mileage is about 10,000 miles.
    Sometimes when I go up from 1st to 2nd gear, the RPM drops and there is a feeling that the engine stops for 1 second. Is it time to replace the HCM filter?
    Northern Kalifornia
    Pull it and check it when you do your next oil change. Buy one and always keep one on hand. Can't really address your first question without knowing what you're riding. I don't think the HCM filter would have anything to do with a lag in your RPM's.
    Default HCM filter
    I changed mine at 32,000 mi., didn't see anything of concern ..... now at 75,000 mi. I'm going to change it ( probably for the last time - I'm 76 ) .... I won't hurt to change it ... but IMHO it's not necessary..... Mike
    Dec 2022
    Republic of Korea
    I'll have to open it up and check it out. Thanks!
    Dec 2022
    Republic of Korea
    Oh.. It's amazing that there is no problem even with a lot of driving.
    Jul 2014
    Mint Hill, NC
    Read pg 110 of your operator's guide and do as you choose.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Aug 2007
    Greeneville, TN
    It is doubtful that you need to change that filter at 10k. The issue you describe does not sound like a transmission fault. I would look elsewhere for a solution. Anything is possible, of course. But if your filter is clogged at 10k (very unlikely). You have a serious problem that changing the filter will not cure.
    Dec 2022
    Republic of Korea
    thank you!!
    Dec 2022
    Republic of Korea
    I'll have to check it out next time I change the oil and take it to the inspection center. T_T
    Very Active Member Isopedella's Avatar
    Feb 2022
    New Zealand
    How would one check a HCM's operation?
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by Isopedella View Post
    You would need a test bench to test flow. You would need to destroy the filter to see if it was clogged. Again, my guess is that something else is creating the issue. It would be expensive. But you could replace the HCM to eliminate it as the cause.
    Feb 2022
    New Zealand
    Ha. Just had a thought. Want a laugh. If you didn't have a test flow set up I guess you could remove, clean it up a bit and see if ya can blow through it.
    I just replaced one on my 3rd hand 2017 F3. Dam. Maybe I could have run my hillbilly test on the old, then the new.
    While it hasn't done mega distance at all but had been there since new. Absolutely probably overkill but I have a datum now with with known oil and filter changes.
    Yeah I know. Thats me over there. Wearing belt and braces with an inch pound wrench in my back pocket and 6 point sockets on the table.
    Jan 2021
    Descanso, CA
    kongdoly -- are you the original owner? If so, at what mileage did you start noticing this intermittent problem? And what is your RPM shift point? Does the problem occur when the engine/transmission are cool from the first run of the day or when they are warmed up after riding for 1/2 hour?
    If you're not the original owner, try the 1-2 shift at 3.5K RPM or higher and see if the problem goes away.
    At 10K miles you should have had a recent oil change. Did the problem worsen or improve?
    2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
    2016 Royal Enfield Classic 500 Fair-Weather Mountain Bike
    Active Member teninospyder's Avatar
    Sep 2014
    tenino, wa
    Changed on our 2014RTL at 5 yrs old - 27,000 mi. (dealer) and last Thanksgiving (DIY) at 57,000 miles. Seems to shift smoother, but that's just me.
    Like Blueknight911, I don't see doing it again (80 Y.O. this May) !
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by teninospyder View Post
    Most likely, the smoother shifting is due to the new oil. Especially if you're using the XPS blended oil and going the prescribed 9,300 miles between service.
