Results 1 to 6 of 6
    Active Member justsmile0808's Avatar
    Oct 2019
    Southampton, NJ
    Default TricLED Daytime Running Light/Fog Light Kit for F3 - $169!!
    Retails for $229.95 on sale at SlingMods!! You will get four (4) - includes a complete new set - for $169 including shipping!!
    Left fog light seemed to dim out on me, so SlingMods sent me two brand new replacements. When I took my Spyder apart, seemed I had an electrical short that was causing the issue. So....you will receive two lights that were mounted on my Spyder, PLUS TWO BRAND NEW LIGHTS WITH PLASTIC STILL ON THEM. I have marked the light that I was having issues with just in case (green painter's tape on the cord). All parts included for install. Visit SlingMods.com for easy install video - see pics for compatibility listing.
    https://www.slingmods.com/can-am-spy...cled?vehicle=1
    Can-Am Spyder F3 LED Fog Light / DRL (Daytime Running Light)
    Introducing the new 2 in 1 replacement LED fog light system for the Can-Am Spyder F3. These fog lights are completely plug and play using factory harnesses already on board your Spyder F3. Even if your F3 didn't come equipped with factory fog lights, the harness to power these will still be on board your Spyder. These fog lights have two LED systems integrated into one housing. The "C" shaped LED arc will run as a daytime running light and has been designed to mimic the F3 front shroud for a face lift that is sure to turn heads. The second is an LED fog light that emits a pure bright white light and includes an OE style push button dash switch to keep that factory Can-Am look.
    Active Member rmag's Avatar
    Jun 2015
    miamisburg, ohio
    PM sent.
    2014 RT Limted, platinum, with matching 622 trailer.
    Ultimate tall boy seat w/adjustable back rest, Corbin armrests, Spyderpops bumpskid & missing belt guard, BRP side air vents, Lamonster lidlox, cargo nets, Stebel air horn, Wrap my spyder accents......and more
    Dec 2013
    Please don't forget that you've posted this thread, and follow the directions in the Sticky re keeping your Ad live, or closing it when no longer needed:
    https://www.spyderlovers.com/forums/...sub-forum-****
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Mar 2017
    Northern Illinois/Southern Wisconsin
    If still available, I will take.
    Dec 2013
    Quote Originally Posted by stevena View Post
    The OP doesn't appear to have visited the Forum, let alone this thread, pretty much since posting this....
    You could try sending an email via the link in the drop-down list that'll appear if you click on their username, but who knows if they'll respond...
    Dec 2013
    Closed due to lack of interest by the OP?!
