Results 1 to 16 of 16
    Feb 2021
    Indiana
    Default Any ingenious ways of hauling Fishing poles?
    Hi Any of you guys have an ingenious way of hauling fishing poles
    I have a 2020 RTL
    Last edited by Peter Aawen; 03-11-2023 at 11:14 AM. Reason: Expanded title to briefly ask the question... ;-)
    Active Member USAF's Avatar
    Aug 2022
    NY
    I was about to ask this same question !
    2022 Spyder RTL
    Feb 2022
    New Zealand
    I have a 4 piece back packer trout rod, comes with a cloth tool wrap type thingi that slides into a screw top tube.
    I guess you could secure the tube to the passenger hand grips or similar.
    Mar 2015
    Fritch, Tx
    I have a collapsing telescoping rod that has 5 or six sections. (haven't used it in a while). It shrinks down to about 14'' & will easily fit in the frunk or trunk. To keep things simple, I put a Zebco 33 reel on it.
    Those who say " I can't" will always be right.
    Sep 2015
    Chilliwack, BC. Canada
    Pocket Fisherman anyone?
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Aug 2013
    SF Bay Area
    A 3 or 4” dia PVC tube with end caps mounted to the trunk rack or passenger floorboard or strapped to the passenger seat might work.
    2021 F3 Ltd , Magna Red
    Quote Originally Posted by bigbadbrucie View Post
    You beat me to that one.
    ... If they are full length, this was my thought also .... Just remove the reels if the rods have them ..... However, if you are going Surf casting - Good Luck! .... Mike
    Aug 2018
    north wis
    Don't know what kind of fish your after but if it's trout or panfish look into Tenkara fishing. I started doing it a couple years back and has been a blast! I got mine from Dragontail.
    2020RTL
    PA
    Do you have a hitch? Could you simply take some 2 inch PVC, heat up and make oval shape. Then take saber saw and cut out a notch on one side. Mount 3 or 4 to a piece of wood and mount to hitch. Place poles on tubes and Velcro. They work on boats, fronts of trucks and rear of trucks for beach fishing. You could also take a piece of 1x12, make a triangle wedge and a 2x12 as a base making a L bracket and mount the L to the hitch. Then use pipe clamp to attach pvc to the 1x12. I’d ratchet strap the bases to the hitch. They would look like huge antennas in the back. You can buy professional hitch pole holders that slide into 1-1/4 and 2 inch receivers too. They are not that much - Hitch mounts for $59.
    Last edited by Peter Aawen; 03-11-2023 at 08:39 PM. Reason: Merged - dunno why you couldn't attach??
    Feb 2022
    New Zealand
    Im after one of these, maybe one day.
    Twizel NZ.
    44 lbs
    https://www.stuff.co.nz/timaru-heral...main-anonymous
    Mar 2021
    Maryland
    I actually had one that I would take with me on my Jet Ski on the Potomac River. Fit right in the frunk of a Kawasaki TS-650 with my other stuff.
    2020 F3 SE6
    2020 F3 , Black
    Dec 2022
    Northwestern ontario
    I carry a 7’ two piece fishing rod. Break it down and put piece of swim noodle around where the trunk lid hits where the rod sticks out from the trunk. Then use elastic to hold the trunk shut. ��
    Active Member Woodenfish's Avatar
    Feb 2022
    Illinois
    I used to fish quite a bit with a Daiwa travel pak outfit. It comes in a small case with room for a spinning reel and some tackle. It was an ultralight outfit and I would run 4-6lb line. I used it for fishing ponds and forest preserve lakes for large mouth bass, bluegills and an occasional catfish. Fishing with an ultralight outfit is a really fun challenge and some of my best memories were while fishing with it. With a little sense to what you’re doing you can land some really big fish.
    2021 Spyder RT Limited Asphalt Gray Chrome Edition
    2022 Spyder RT Limited Hyper Silver Chrome Edition
    Spyderco Paramilitary 2
    Vanquest Gen 2 7x10 First Aid Trauma Pack
    Garage Door Opener
    iPass
    DJI Action 2
    Tackform Anti-Vibe Phone Cradle
    UltraGard Full Covers
    Show Chrome rear trunk lid lift strut
    Noco Genius 1
    Noco GBX Booster X
    Show Chrome Platinum Grande Adjustable Padded Driver Backrest with Storage Pouch
    Baseus Cordless Inflator
    See if you can see this web page. https://web.archive.org/web/20160328...r-tote-spline/ The link is to a 2018 web page by John Seal who developed a hitch mounted carrier for golf clubs. Maybe it'll give you an idea or two. John had to leave the Spyder scene several years ago due to health problems and sadly was unsuccessful in transferring/selling his product designs to anyone else.
    Aug 2018
    Columbus
    a YouTuber who had a ryker used the link rack system... i think the same system works on rt20+
    https://youtu.be/j2U1wgWtSEw
