Results 1 to 4 of 4
    Jul 2021
    Vancouver BC and Palm Desert CA
    Default Is Blue Ridge or Route 129 w/screen h/ware available separately?
    Does anyone know if the hardware is available without buying the windscreen. I want to use an aftermarket screen on my F3S and would like to avoid paying for a windshield I never intend to use.
    An online search didn’t get any results and I gave up after more than 20 minutes on hold for the dealer’s parts dept.
    Thanks
    Last edited by Peter Aawen; 03-11-2023 at 02:18 AM. Reason: Expanded title to briefly ask the question... ;-)
    2021 Spyder RT Limited (Palm Desert)
    Grey - dark edition
    2015 Spyder F3 S (Vancouver)
    2017 Yamaha V Star 1300 Tourer
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    Methinks you have to go to a Spyder Salvage Yard, as those components you seek are not available via BRP, maybe via Ebay.
    the funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it........
    Spyder F3s 2019 All Black ( Named it: Brutus)
    Carbon Items added, just for looks
    Upgraded Shocks Trac-Tive, Rear hi/lo and rebound adjustable, with Hydraulic Pre-Load adjuster
    fronts hi/lo and rebound adjustable, custom made by the Trac-Tive Guru's
    Swaybar (Ron's)
    Tyres Front Michelin Cross Climate+ 175/60-15
    Rear, for 2022 still a Kenda, next Yokohama Advan Fleva 205/55R15
    Exhaust Bone stock, with a RLS Cat- Delete
    Custom ECU-Mapping, rewritten/adapted to my Ridingstyle
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Feb 2022
    very southern tip of Texas
    Don’t have my assembly instructions in front of me but, IIRC, the main 3 mounting brackets only come with the R129 or BR kits.
    White 2015 F3-S SE6 - “Gypsy” (hers)
    Yellow 2017 F3-S Daytona 500 SM6 (his)
    Active Member 3Tyme's Avatar
    Feb 2019
    SE Ohio
    Gustafsson makes models for both BRP and their own mounting hardware. I have one with their mounting hardware. It wouldn't have been my first choice, but it was installed by the previous owner. I don't think I will change it unless I find the BRP mounting pieces at a bargain price.
    2015 F3-S , Silver
