Results 1 to 21 of 21
    Active Member tntnj's Avatar
    Sep 2015
    JerseyShore
    Default If you bottom out your 20-22 Can Am watch this video
    https://youtu.be/nVOrlqoijao
    There should be a stronger replacement by BRP.
    2017 F3 LTD (SOLD)
    2017 HD Freewheeler (SOLD)
    2021 RT Base Upper and lower adjustable deflectors , Top case, Signature and lower lights, Baja Ron Bar, Back rest,Fobo TPMS, Garmin 396 , LED Fender lights, Rear LED turn and brake lights, Rear Brake light flasher, Rear Saddle bag LED lights, Battery tender, Lamonster Handle Bar Riser.
    Clinton, MS
    That's very interesting. Will have to look at a few.
    2019 RTL Phoenix Orange
    I've seen things ( on this forum ) that are at Amazon .... that you can put inside the spring COILS that will stiffen the OEM springs. .... cost about $ 15.00 ...... Mike
    Active Member Rednaxs60's Avatar
    Mar 2021
    British Columbia
    This is a forum member who changed out the OEM rear shock spring for a 600 lb/in shock spring. Good reading.
    https://www.spyderlovers.com/forums/...ension+upgrade
    "When Writing the Story of Your Life, Don’t Let Anyone Else Hold the Pen"
    "Too many of us are not living our dreams because we are living our fears.” – Les Brown
    2014 Can-Am Spyder RT LE
    1985 Honda GL1200 Goldwing Limited Edition
    Ernest
    Durham,Maine
    What is busting? Is the top of that shock mounted in plastic? Sometimes I'm glad I am riding old iron!!
    2012 RTL , Pearl
    Sep 2015
    JerseyShore
    It sounds like a plastic bracket on the bottom of the shock, not really sure. I will have the dealer check when I get the brake switch and the read tire replaced.
    2017 F3 LTD (SOLD)
    Oct 2020
    Vinton, IA
    First, neither end of the rear shock is mounted in plastic.
    I believe the piece he is speaking of is a shroud/liner that prevents road crap from getting thrown forward into the suspension, tank and onto the cat. If that piece is getting damaged, there are a number of other possibiilties for bottoming out: the air ride pump sensor isn't calibrated correctly, it doesn't have a pump and should be manually charged for the increased weight of a rider, or the style of riding in general.
    While the OEM coil-over leaves a lot to be desired, the only weak structural part in the rear, that I know of, is that the lower bolt holding the shock. It is soft and bends over time; Marcus @ M2 Shock covers this in his video series.
    2020 Spyder RT Limited; Deep Marsala/Chrome
    Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
    General Altimax RT43 215/60/R15 on factory rear
    Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
    Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
    Extra LED lighting and misc. to suit my needs/wants
    Apr 2023
    Red Deer, Alberta
    I too would like to know what was getting broken as the video doesn’t show this well.
    I found my licence plate was getting bent from touching the trailer hitch ball when bottoming out. I don’t want to spend $900 on a different rear shock so am looking for options.
    Mar 2015
    forrest above Reno, Nv
    Lightbulb coil spring stiffeners
    I have these on the front and rear shocks. They do help for not much Denero($$$)
    Lew L
    2014 RTS , Circuit Yellow
    NorCal - Northbay
    A word of caution... DON'T do it!! The springs aren't designed for and can't handle the "side loading" and flex inducing fulcrum points that these "inserts" create and will eventually break! Can't tell you how many I have pulled out of cars with broken springs...
    OP: A happy middle ground would be to just change the spring if you don't wanna drop the $ for a new shock..
    Chuck
    Sep 2015
    JerseyShore
    Spyderdave is correct. If you look at the video in theater mode (enlarged) you can see the plastic that is broken. It looks like the bottom of plastic shroud is damaged. It does not effect the handling. So I don't think you would need a new Elka shock for $900.
    2017 F3 LTD (SOLD)
    Apr 2023
    Red Deer, Alberta
    I tested the air pressure in mine tonight. I put a gauge on the schrader valve and started the machine. It pumps up to 38 psi with me on it. So I manually added up to 60 psi. I weigh 225. Started the bike again and bounced the bike around just sitting in my shop and it deflated down to 38 psi at little bit at a time. Not a leak but the levelling valve letting out the air.
    There must be a way to adjust the linkage on the levelling valve I would think.
    2022 Spyder RTL Marsala Red Chrome
    Quote Originally Posted by 2old2fly View Post
    Only in the software! And you'll need BUDS to do that, plus someone who knows how to reset the upper & lower limits for the ACS.
    Apr 2023
    Red Deer, Alberta
    Checking with a dealer tomorrow and hopefully they know how these work. Thank you
    Apr 2023
    Red Deer, Alberta
    Dropped the Spyder off at the dealer this morning and was told they could look at it. Called this afternoon and was told maybe the middle of July.
    Has anyone lengthened the control rod to raise the air bag pressure? I think I may try that as I would like to use the bike while I can.
    Apr 2023
    Red Deer, Alberta
    Today I adjusted the control sensor mount till I got 60 psi with me on the bike. I reached up inside where the mount is with a small crescent wrench and twisted the bracket down toward the rear of the Spyder till I got the pressure I needed. Took it for a ride today, 400 km, and it worked much better but the shock absorber is not strong enough as it allows too much movement in the suspension. I may need an aftermarket one especially if I ride 2up.
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    can you show a pic of how you did that? Did you bend the bracket or just adjust it ? did you look into getting a custom rod that was adjustable instead ? Would it be like 2 rod ends and rod with jam nuts? McMaster- Carr has lots of rod ends and rods/jam nuts....
    Has anyone measured the length, hole diameters, joint sizes etc
    Apr 2023
    Red Deer, Alberta
    I did not get any pictures but if you look where the sensor is mounted it is just light metal. So, yes I twisted the mounting toward the rear of the bike and down very slightly to get the pressure I wanted in the air bag. Very simple to do and the same as lengthening the rod.
    Durham,Maine
    I am beginning to feel like Peter and Blueknight with the tire threads, only on this subject... but, you can bend the arm and hope it will not break, only remember one thing - the system you're playing with is still a piece of junk and the compressor will leave you sooner or later! I would just spend a couple of bucks and make that system a manual fill; a piece of air-line and a coupling and you can set it and forget it!! Just my 2 cents!!
    2012 RTL , Pearl
    Dec 2022
    Florida
    Im with mikey, thats what i love of my f3t,manual air pressure, less things to fail and adjust at your needs
    Apr 2023
    Red Deer, Alberta
    I agree, it is a very poor system for something this simple however if I can keep it working then I don't need to adjust the pressure manually when I go from 2up to one or vice versa.
