Results 1 to 7 of 7
    Mar 2018
    LV
    Default Should a 2019 F3 have a factory fitted/stock Belt tensioner?
    I just purchased a 2019 Can Am Spyder F3.
    Question is--does it come from the factory with a belt tensioner?
    Thank you
    Last edited by Peter Aawen; 03-07-2023 at 03:22 PM. Reason: Expanded title to briefly ask the question... ;-)
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    No only 2022+
    Active Member Tourer's Avatar
    Jul 2022
    North Carolina
    Here is a parts diagram for a 2019 f3. Item number 350. Part number 219800431.
    https://www.canampartshouse.com/oemp...ve-system-rear
    ASSEMBLIES WHERE 219800431 IS USED
    2018 F3 S SM6 & SE6 - Rear Drive
    2018 F3 T SE6 - Rear Drive
    2019 F3 S SE6 - Drive System, Rear
    2019 F3 S SM6 - Drive System, Rear
    2020 F3 S SE6 - Drive System, Rear
    2020 F3 S SM6 - Drive System, Rear
    2021 F3 S - Special Series - Gravity Grey, (Built After Sept. 2020) - Drive - Rear Common Parts - North America
    2021 F3 S SE6 - Monolith Black Satin, (Built After Sept. 2020) - Drive - Rear Common Parts - North America
    2021 F3 S SE6, (Built Before Sept.2020) - Drive System, Rear
    2021 F3 S SM6, (Built Before Sept.2020) - Drive System, Rear
    2015 F3S SE6
    Mar 2018
    LV
    thank you
    Apr 2019
    Florida Swamp
    2019 F3-S would have one. Mine came with the belt tension-er from the factory.
    2019 F3-S , Black & Silver
    Aug 2013
    SF Bay Area
    My 2021 F3 Ltd did not come with one and I added the BRP one that I got from LaMonsterGarage that comes with a better wheel and bearing. Easy install.
    2021 F3 Ltd , Magna Red
    Quote Originally Posted by foolofsand View Post
    Thank you
    I wouldn't buy one, it's not needed!!!! .... if that tensioner FAILS and it eats your belt it will cost you about $500+ (if it happens in your driveway - which is not likely ) ..... Good Luck .... Mike
