Results 1 to 25 of 48
    Apr 2018
    Texas
    Default What oil are you using for your 1330 engine?? Tips & hints on oil change?
    I did a search but only found some post a few years old on the subject.
    What oil are you using for your 1330 engine? I have a 2018 and a 2019 F3L. Just got a quote from the dealer to do an oil change. Not trying to be funny but it sounded to me like I was gonna pay to put his kids through college cost. Found several youtube videos and it looks like something I can do. I would appreciate any tips and or techniques you could share. Also trying to find if I can get the oil locally.
    John
    Last edited by Peter Aawen; 03-04-2023 at 12:45 PM. Reason: Expanded title to briefly ask the question... ;-)
    indpls in
    lamonster sell the tools needed and an oil change kit
    Active Member helton61's Avatar
    Jan 2023
    Virginia
    Rotella T6 5w40 for me less than 50 bucks for a change.
    Dec 2022
    NY
    Personally putting an oil that has additive packages that formulate it for a diesel has no place in my bike; but that’s just me. I know a lot of guys do it, but I prefer to stick with an actual motorcycle oil. I only run Mobil 1 10-40 Racing 4T in my bikes, along with BajaRon’s filter kit.
    ~~2010 RS SE5 My first Spidey, but not my first ride~~
    The trigger’s been pulled. We have to
    get there before the hammer falls.
    Active Member Tourer's Avatar
    Jul 2022
    North Carolina
    Rotella 15w40 T6. 2.5 gallons at Walmart for $60. Oil filter kit from BajaRon or Lamonster.
    Stainless steel drain plug from Votex
    https://votex-us.com/DP035
    2015 F3S SE6
    Quote Originally Posted by helton61 View Post
    ...been using it for many years .... It can be bought for less .....JMHO .... Mike
    Quote Originally Posted by DaniBoy View Post
    Yep that's just you ...... The Rotella T-6 is JASO II rated ..... Mike
    Jan 2023
    Virginia
    Yes that includes oil filter too.
    When I bought my 14 RT new I also bought a case of oil filters ( on-line ), They were about $5.00 each ..... Mike
    Sep 2016
    Chillicothe, Oh.
    And we're off to the races. Let's do tires while we're at it.
    Since you asked Rotella in my 1330 as in all of my bikes with trans/engine unit for years. Three of those bikes have an excess of 100,000 miles on them. My BMW and Guzzi have separate transmission and engine setups with a dry clutch so a different animal.
    2015 RT , Black
    Dec 2019
    Land of Lincoln
    Quote Originally Posted by Revrent View Post
    John
    You'll get a hundred different answers here.
    Rotella is fine, and it meets the spec for the clutch. No harm in a diesel oil in a motorcycle. Primary difference is a small amount of silicone added to minimize foaming in a HEUI diesel engine so the injectors will fire properly. Silicone won't harm a gas engine. Get it at WM.
    Supertech Motorcycle Oil, made by Warren. Good oil, available nationwide at WM.
    Valvoline Motorcycle oil is relatively cheap, meets the spec, and is available locally most anywhere. (WM and AZ)
    Castrol can be found in some auto parts stores. It's fine as well, and Castrol is rumored to make the BRP oil. (AZ)
    Shell Advance Motorcycle oil. Great stuff, finally imported due to demand. (Advance Auto)
    I'm running Mercury Quicksilver. Found on closeout a few years back for a couple dollars a quart.
    I bought all 4 cases right then. Meets the spec, works fine, no bad habits.
    Still in the wild in a few places, and Amazon for 33.xx a gallon.
    Read the label, you are looking for a 10w or 15w40 for summer, JASO MA, and whatever your finances can afford. 5w40 if you are a diehard that rides all winter. If it meets the spec, it meets the spec. So called "conventional" oils, change a bit more often, synthetics, run them a little longer if you choose. I still don't agree on the 9000 plus miles BRP calls for regardless of oil or type. Oil changes don't have to be stressful or require a second mortgage.
    Oct 2021
    Wichita, KS
    Your search must be broken. There have been 3 or 4 oil threads on here in the past couple of months.
    No kidding. Gotta love oil and tire threads.
    Peter Pan has struck again!
    Clinton, MS
    Here we go again.
    2019 RTL Phoenix Orange
    If you read your operator's guide and use oil that meet the API Service Code(s) for your engine you aren't going to go wrong. The only way you can know how the oil is performing is to have it analyzed.
    Jan 2023
    Virginia
    I bought some hiflo filters off of amazon for 6.74 without the orings or washers.
    Dec 2020
    Hartwell, Ga
    Here's my 2 cents worth.
    I only run Mobil 1 10-40 Racing 4T in my bike also. Good stuff and IMHO it will quieten the transmission clunk to hardly noticeable.
    Dec 2020
    Hartwell, Ga
    I purchased the K&N straight from K&N on sale for 8.79ea and free shipping as I purchased 3 of them. Both are really good filters.
    Mar 2022
    Ottawa, Ontario
    I bought the same for my 2019 RT LTD, no issues
    2019 RT LIMITED , Intstalled Phoenix Orange
    Mar 2021
    Maryland
    I just buy my oil with the filter kit and ebc brakes for my yearly spring maintenance change out from lamonster. I also bought the K+N air filter this year so I don't ever have to buy one of those again.
    Tried and true products and formulated just for our machines.
    2020 F3 SE6
    2020 F3 , Black
    Durham,Maine
    John
    Have you ever used the little search engine at the top of the page, if so, you will find thousands of oil postings till your eyes bleed! As far as what oil to use, just make sure it's wet clutch compatable, and use whatever you want!! Good luck my freind, now off to the races we go!!!
    2012 RTL , Pearl
    Apr 2020
    Edgerton,WI
    Thumbs up Drink the Kool-Aid
    After reading all the opinions and my research, I’ll drink the Kool-Aid……..I will begin using Rotella 5w-40 in my Spyder 1330.
    2019 F3L , Covid Blue
    Quote Originally Posted by bikerchris1270 View Post
    Actually using Superior NON-BRP products ..... is NOT drinking the Kool-Aid ....JMHO ....Mike
    Dec 2021
    Oregon
    2021 Spyder RTL. my last oil change at the dealer was $300 +-. I looked at the parts list used and was shocked what few parts were used.
    I decided put this 76 year old body on the floor and change my own oil, like I was still in my youth.
    CORRECTED:
    IT WAS POINTED OUT TO ME THAT THE OIL I USED WAS NOT FORMULATED WITH JASCO MA2 AS REQUIRED BY BRP.
    I DRAINED THIS OIL AND REFILED WITH:
    VALVOLINE 10W-40 MOTORCYCLE 4 STROKE FORMULATED WITH "JASO MA2".
    THANKS
    THANKS FOR THE HEADS UP.
    Oil change parts I used
    Ref:25 O-Ring 420430115 1.97
    Ref:24 O-Ring 420250460 1.97
    Ref:26 Metal Gasket Ring 420430623 1.34
    Ref:38 OEM Oil Filter 420956744 17.09
    **#39 OEM Oil Filter Cover Ass'y Includes Items 39 to 42 Part Number 420210885 if needed
    Ref: 40 OEM Oil Filter Gasket #420850482 6.99
    #41 OEM O-Ring 420950812 Filter Rod $5.59 if needed
    #42 OEM O-Ring 420650927 Filter Rod $5.59 if needed
    Total Parts I used= 29.36
    https://www.canampartshouse.com/oemp...ne-lubrication
    [img]
    Florida Swamp
    I use Lucas High Performance Motorcycle Oil, Synthetic 20W-50.
    It is approved for wet clutch applications. Have also used the Mobil1 4T in the past, but mostly stay with the Lucas Motorcycle Oil.
    I don't really think it matters much what brand you use, if it is approved for wet clutch and you are changing it on a regular basis.
    Changing the oil is not rocket surgery........ basic hand tools, and automatic transmission funnel.
    2019 F3-S , Black & Silver
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by Crewless View Post
    I decided put this 76 year old body on the floor and change my own oil, like I was still in my youth. The Total cost of this oil change was $59.33
    I use 5w40 Mobil 1, full synthetic.
    Mobil 1 Full Synthetic 29.97 Walmart.
    Total cost of this oil Change = $59.33 + plus about a slow 1hr's work for me.
    I looked at the specs and this does not appear to meet the requirements for our engines/transmissions unless I missed something. Check for yourself and good luck. I did not see a JASO classification.
