Quatrac 5 - Size: 155/60R15 no longer available?
ive read on here that these were no longer available ? Hummm, so which one, old or new version to buy.
https://www.tirerack.com/tires/tires...5QT5&tab=Sizes
2020 F3 limited, liquid titanium
grip puppies
Bajaron sway bar
lamonster belt dampener
battery tender
19 in freedom tinted windshield
matte black daytona frunk wrap
Quadtrac 165/60's
Look at the Quatrac (no 5) for replacement. Excellent cold/wet weather tire. The Q5 was asymmetric, the Q is symmetric tread pattern.
Ozzie Ozzie Ozzie
Regardless of the tire, if you're talking Spyders & not Rykers, the OE width is 165, and I really don't think you'll want to go as narrow as a 155!
2013 RT Ltd Pearl White
Ryde More, Worry Less!
SpyderLovers Sponsor
The Quatrac is a fair amount better than the older (discontinued) Quatrac 5 (which was a great tire). I assume they achieved this by going with a directional tread. Strange naming pattern. But great tires!
Tire Rack has the older Quatrac 5 in 155/60r15 in stock. But I am with Peter. Not sure why you would want that size.
I installed these, 175/55R-15 VREDESTEIN QUATRAC SL, on my 2021 S2S earlier this month and they are working great.
I dont know how many times I have posted that there is no such tire as a QUATRAC SL, Way too much miss information picked up by people here and passed on.
Quatrac SL .... never heard of it & tire rack doesn't sell it .... JMHO .... Mike
T.P.
2021 Spyder RT Limited (Sea-To-Sky)
2022 Ryker Rally
Product order confirmation from tire rack for a Quatrac SL, I think this is where the confusion comes from....
Update: I think they added in SL just for us Spyder Lovers... It's a Spyder Lovers edition Quatrac!!!
2020 F3 SE6
Safety and Lighting: LED Headlight upgrade, IPS LED Fog lights, Show Chrome LED Fender Signals, LED Signature Light, Tric LED Afterburnerz, MotoHorn 2.0
Suspension: Wilbers Front and Rear Shocks, BajaRon Sway Bar, Vredestein Quatrac Front and Rear Tires
Comfort: Blue Ridge Windshield, Corbin Dual Touring Saddle, Ultimate Floorboards, OEM Passenger Backrest with Rear Shelf, OEM Passenger Floorboards Modified with High Risers from Pierre
Tackform Center Mount Phone Holder w/ rapid charging USB-C.
Some possible clarity on the SL.
I just ordered a set of 4 Vredestein tires for my son’s truck. They offer a 3 ply and a 2ply in the same model and size. The three ply is labeled LTS and the two ply doesn’t say SL on the listing but does say SL on the receipt. I looked up SL on Tire Rack’s site and SL stands for “standard load”
2022 Ryker Rally
There is no such tire as a VREDESTEIN QUATRAC SL, The SL stands for Standard Load and has a max pressure of 35psi, XL's are to 41psi
It is not a tire model
We need to be exact on fitting car tires on our Spyders so that someone doesn't end up with a deadly combination of type or sizes of miss matched tires.
T.P.
Quatrac ...... "SL"
Thanks to all who helped clear up this bit of confusion ...... None of the Ads for Vredestein tires mentions the "SL" ...... Mike
Reason: Moved Post title into text - many won't see post titles, only the Main Thread Title! ;-)
Originally Posted by Peter Aawen
Regardless of the tire, if you're talking Spyders & not Rykers, the OE width is 1 65, and I really don't think you'll want to go as narrow as a 155!
ahh, i did not catch that, too narrow,, my bad.. tks.. getting ready to upgrade OEM fronts, my local shop said he can change them and balance them, he has a 40MM cone for his machine.
grip puppies
Bajaron sway bar
battery tender
Quadtrac 165/60's
The 'SL' on the Quatrac is a Tire Rack designation. It has nothing to do with the manufacturer. In this case, Vredestein. So, everyone is right! There is no such thing as a Quatrac SL. And, at the same time, there is! Not often that everyone is right!
grip puppies
Bajaron sway bar
battery tender
Quadtrac 165/60's
