Rough Idle on startup, settles once warm - any ideas?
My 2019 F3 Ltd is idling rough on startup, settles down once it gets up to running temperature, but rev counter needle still fluctuates between 800 & 900 revs, bike has a stage 2 tune in it, when hooked up to diagnostic tune reader there's no fault codes. Should I be worried? Done 40000 Kays. Thanking you John
Reason: Expanded title to briefly ask the question + ' 's & Caps ..... ;-)
Ozzie Ozzie Ozzie
Who did your Stage 2 Tune?? I'd give them a call & ask, but I reckon it sounds like it's doing pretty much exactly what you'd expect... rough idle until warm, and the electronic tach needle bounces a bit at idle...
Ride More, Worry LESS!
2013 RT Ltd Pearl White
Ryde More, Worry Less!
Peter it was Jase, done about 15 th kays since installed, will be getting the 45 th kilometers service done shortly, plugs & fuel filter replaced. lnteresting to see if anything changes. Thanks for the reply.
Reason: ' 's ;-)
Ozzie Ozzie Ozzie
If you're concerned, give Jase a call, I'm pretty sure he'll be happy to talk any concerns you might have thru with you.
