Results 1 to 11 of 11
    Active Member linguine's Avatar
    Feb 2023
    AZ
    Question Need to remove grille to get behind the speaker - How?
    Howdy do to all,
    The previous owner of my 2020 Spyder RT Ltd said there was a Pedal Commander stashed behind the right speaker (I know there are two grilles; he was not specific), and that I could remove the grill and then pair my phone (via their app) to it.
    I am at sea here. Any step-by-step would be greatly appreciated.
    Last edited by Peter Aawen; 02-19-2023 at 09:55 PM. Reason: Removed Prefix - this is not a HowTo: DIY thread... & expanded title to briefly ask the question + 2020 not 2032?! ;-)
    Ride safe; shiny side up, greasy side down.
    best,
    linguine
    2020 RT Limited , Chalk Gray
    Bossier LoUiSiAna
    On my 13STL, they just pushed in - small tabs in a few places to line up. Otherwise just careful not to bend & warp them out of shape
    Feb 2023
    AZ
    I'd be afraid of cracking them. Phoenix heat in the summer gets over 110, making plastic brittle...
    best,
    linguine
    Quote Originally Posted by linguine View Post
    I would be more afraid at removing them at -20 F then at 100 F ..... Look at a Fiche' for your year & model Spyder.... it will show you how it's attched and where .... good luck .... Mike
    Feb 2016
    They are very easy to flex and will pop right out. Use a small flat blade screwdriver, nail file, or preferably a plastic body trim removal tool at the outside edge and pry it out toward you.
    2020 RT Limited , Marsala Red
    Oct 2020
    Vinton, IA
    A butter knife works great, but I don't tell the Mrs.
    2020 Spyder RT Limited; Deep Marsala/Chrome
    Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
    General Altimax RT43 215/60/R15 on factory rear
    Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
    Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
    Extra LED lighting and misc. to suit my needs/wants
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    they pop right off, just get a finger nail under a corner and lift
    Feb 2023
    AZ
    Thanks everyone!! Puts my 78 year old gray matter at ease.
    best,
    linguine
    Feb 2023
    AZ
    Cool
    Got her done.
    With a WickIt Stage 2 ECU tune, Akropovic exhaust, and RLS Cat Delete tube, this thing was an unruly monster. Fast as f#-#-ck, but neck snapping shifts. Turns out the former guy had the Power Commander set to Sport +4 !!!. I dialed it way back to Eco , and with the bike set to Eco, my wife no longer fears to drive it.
    With the WickIt ECU tune, less than half throttle makes the bike tame in all-Eco setup. More than half throttle, and all those extra horses and torque are instantly available. I have the best of both worlds.
    Now, one day I'll put the Power Commander in Track Mode, and this 78 year old might be posting from jail in the future.
    Thanks again for all your kindly help!
    best,
    linguine
    Durham,Maine
    I hope you put it somewhere to play with, when you're by yourself and want to be froggie!!
    2012 RTL , Pearl
    Feb 2023
    AZ
    I just use the app via BT. No need to mount it or take it out of the cubby.
    best,
    linguine
Tags for this Thread
