Results 1 to 15 of 15
    Active Member budvoss's Avatar
    Dec 2010
    S.C.
    Default Recommendations wanted - Best cover for 22 RT?
    I need a cover that will cover the complete machine. Can anyone recommend a vendor that sells them that cover wind screen, fenders, frunk, and trunk. It's a 22 RT.
    Thanks all.
    Last edited by Peter Aawen; 02-16-2023 at 05:09 PM. Reason: Expanded title to briefly ask the question... ;-)
    2022 RT Limited
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    Nov 2013
    Central Texas
    I have the same one. It works very well, and is quite durable. I have found it's much easier to put on in daylight. It's hard to sort out in the dark.
    Dec 2010
    S.C.
    Thanks guys
    2022 RT Limited
    My Spyder is stored inside .... I just use a King size sheet ..... Mike
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    I have the factory cover for mine but I use golf cart covers from Formosa Covers. They are in expensive like $25.00 in expensive and very durable. I also use them to cover my outdoor kitchen sections
    2022 RT Limited , Silver w/ Black and Purple accents
    Dec 2010
    S.C.
    The problem i have is with daughters cat. It loves to get into every thing including laying on spyder seat. Sheet wont work for me as he will just go under it lol . My rig is garage kept but the cat gets in when door is opened lol. Thinking maybe a tight cover can keep him off of from going under cover.
    2022 RT Limited
    Quote Originally Posted by budvoss View Post
    If that's the case, a tight cover probably won't work, but mothballs should!
    If scattering the mothballs around &/or on the Spyder doesn't deter him, then get hold of an old paintball gun; load it up with mothballs; dial the air pressure right down so that the mothballs don't disintegrate on leaving the muzzle; & do some target practice using the cat as a low flying target whenever it even looks at your Spyder or thinks about going into the garage whilst said Spyder is in residence!! If you do it right, he'll never know where they're coming from, but they'll both hurt and stink enough that he'll begin to associate both the sudden pain & the not very enjoyable stink with looking at your Spyder, and so he'll learn very quickly to steer well clear of it!
    This works, very well! Do you really need to ask me how I know this for a fact??
    Notice: No cats were permanently harmed during the testing of this protection aid - altho a few of the neighborhood cats were possibly lightly bruised juuust a little before I got the air pressure dialed back enough to prevent the mothballs from disintegrating before they got out of the barrel, but once I'd done that & they worked as projectiles, I'm sure it was the lingering taste & smell of powdered mothballs all thru their fur that put them off more than anything else!
    May 2013
    Apex, N.C.
    I agree with the above statement. A tight cover will not keep the cat out. My spyders stay in the garage with my office cat, but she doesn't bother it. I did have to relocate my convertible to the attached garage, as that would be quite an expensive lesson if she decided to claw into my top. I only use my spyder cover when traveling to keep the instument panel and seats dry. I bought a travel cover for my 2014 RT. Since then I have used it on my 2012 RSS, 2016 F3T, f3 Limited, and now for my 2021 RTL. It works to do the job on all of them.
    Active Member Tourer's Avatar
    Jul 2022
    North Carolina
    I like Mike keep the Spyder inside and use a king sized bedsheet. Wanted something fancy so it’s a floral pattern.
    Also had problems with the cat getting on my Gold Wing seat. Had to spread Chinese food take our menus around the bike to keep the cat away.
    Active Member Pooch's Avatar
    Feb 2018
    Texas Hill Country
    A friend had the same problem with cats... was told to spray the ground and bottom of bike cover with regular vinegar as the advisor said cats hate the smell of vinegar. He said it seemed to work for the 3 nights he tried it as his trail cam caught the cats coming to the bike and passing it by. Then he moved the bike inside his toy hauler garage due to unstable weather so hasn't had a chance to further try out the vinegar hypothesis.
    2021 RT Ltd, Marsala Red/Black, Dark
    New course heading Mr Sulu: 2nd star to the right and straight on til morning...
    Oct 2021
    Wichita, KS
    Quote Originally Posted by SLICE View Post
    I agree. The UltraGard is a good cover. I have both the full and half. I have no idea about cat protection though
    Peter Pan has struck again!
    Member Arachnerds's Avatar
    Mar 2021
    South Dakota
    How about covering the seat with aluminum foil when you are storing it? Cats get freaked out when they jump up and land on it. Another idea is to cover the seat with a really large garbage can bag. The plastic will likely not be very comfy for a cat and if they still jump onto it, it should be a bit more protected.
    2011 Spyder RT Limited
    Quote Originally Posted by Arachnerds View Post
    I can't speak for All cats .... however my cat Loooooooooooooooooooooooooooooves plastic, He is constantly finding and chewing on it. ..... JMHO .... Mike
    May 2019
    Michigan
    I have an old 1985 Oldsmobile Toronado (last of the big ones) cover. I put Bounce softener sheets/tissues inside and and around. RTL is inside, so loose over-size is not an issue.
    2022 RT Ltd, Deep & Dark Marsala
