Results 1 to 12 of 12
    Feb 2022
    New Zealand
    Default What is the cover you need when you remove the top box?
    I have a 2017 F3 Ltd with top box. Im thinking I may like the option of running it without the top box from time to time.
    What is the cover called I need if I remove it. Then I guess where do I get one, part number?
    Cheers Iso in Kiwiland.
    Jan 2021
    northeast pa.
    Quote Originally Posted by Isopedella View Post
    https://www.spyderlovers.com/forums/...unk-be-removed
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
    Very Active Member YPILOT's Avatar
    Aug 2009
    Johnson City,Tennessee
    The top case 2017 F3 limited bolts into position unlike the newer 2020+ machines with the Linq system.
    That being said what you need is the parts for the rear from an F3 T. It may take a bit more effort to change them out but could be achieved. Check the parts fiche for the F3T and the F3L to see the differences.
    "Stupid is as Stupid does"
    Don't Drink and Drive or Ryde!
    Each Day is a Gift
    Feb 2022
    New Zealand
    Cheers for the replies. Himmmmm.... May not be worth the effort in thinking now.
    Feb 2022
    New Zealand
    So I sorta went away from the removable trunk.
    Then I found a video.
    To remove, few bolts and some plugs.
    Does not seem too arduous at all.
    So I guess I'm back in the hunt for that cover?!
    Oh, here is where I got my info from.
    https://www.youtube.com/watch?v=C4ihJHPQTbM
    update
    Found a black one
    Can-AM OEM Rear Fairing, Deep Black Model #: 708302912
    Costings
    $276.74
    Shipping
    $203.86
    Total
    $480.60
    Cheers. That ain't happening!
    Sep 2022
    BC
    I have a 2017 F3 Limited in white and ended up buying the cover, which only came in black. I actually don't mind the look. Ended up using plasti-dip on the windshield, so I have a bit of a white/black theme running :-) The part number is 708001786, and I paid $255.00 Cdn. Not the best pics but you can kinda see how it looks.
    Florida Swamp
    The cover is called a "Laundry Bag". There is no part number. You were issued one when you reported for basic training.
    2019 F3-S , Black & Silver
    Vermont
    update
    Found a black one
    Costings
    $276.74
    Shipping
    $203.86
    Total
    $480.60
    Isopedella,
    I have a 2023 F3 LTD Special Series, and I was thinking of doing the same thing to mine (removing the top case and replacing it with a plate). I am not going to be doing that.
    I saw the u-tube video, and mine does not have the USB port in the top case at the bottom, all it has is the hole for one.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Feb 2022
    New Zealand
    Quote Originally Posted by Gwolf View Post
    HAHA, Nope. Summer 1975 Waiouru Camp for Basic and then Specialist training. RNZIR.
    Gave us the runaround and nothing is good enough for a while, then I learnt how to take these 4X4 trucks into places you wouldn't believe.
    2017 F3 Ltd
    Feb 2022
    New Zealand
    Isopedella,
    Deanna
    I seem to recall the wiring is there in the loom but not the plug. Or something similar.
    If you wished you could pick up and retro fit a plug maybe?
    I do use my trunk usb on longer trips charging for stuff along the way.
    2017 F3 Ltd
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by bbhw73 View Post
    I really like the effect of the black tail and shield. Have you thoight about doing your center consol up to the instumment pod in the plasti dip also?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Vermont
    Isopedella,
    OK. Some time this spring I'll take a look.
    At some point I'll install a plug.
    I haven't used the usb in my trunk. I have a power plate on my handlebars that I use for charging my electronics.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
