What's the Color of the Tail Light wire on an F3s?
Can anyone tell me what color the wire is for the Tail Lights on a 2016 F3s?
I assume ground is BLACK
Need to know the Tail Light wire color?
Thanks,
ROTAX
Curious as to why you cant have a look for yourself ?
It’s not a good idea to tap into the OEM wiring as it will cause the system to complain. You’ll need some 1N4004 or similar diode in the positive lead to the LED strip, banded end of the diode to the LED strip so as to, in a way, keep the extra lights a secret from the OEM lights.
you can always find out wire by a 12V tester with that needle point end
Hope this helps. Info is from my 2017 F3T.
Rear Light Wiring F3T
Which one for just the Brake Light.
I want to connect to the brake light on my F3-T. The F3-T uses turn/brake for the same wire. Sooo how do I hook up just for the brake lights only?
In those plugs, the wires are thus:
Right Signal = BLACK/YELLOW
Left Signal = GREY/PINK
Running Lights = WHITE
Brake Light = ORANGE
BLACK = ground
backup = PINK/BEIGE
Wiring diagram attached.
David C
2016 F3T
Battery tender cable
Rear IPS Pack Rack
