Results 1 to 7 of 7
    Nov 2022
    WI
    Default Is there a four pin trailer adaptor to take square plugs to flat?
    My Spyder came with the hitch and lighting, but the square four pin trailer light plug on the Spyder does fit the flat four pin on my trailer. Does anyone make an adaptor for the RV square four pin to a flat pin?
    Idaho
    Quote Originally Posted by dataWrangler View Post
    The quickest and easiest fix is cut the flat four in two and tape it together in a square. It'll plug right into the square 4 connector.
    2014 Copper RTS
    Nov 2022
    WI
    That is a great idea, thanks.
    Dec 2015
    NE Ohio
    You can also buy the square and flat connectors online and make one yourself any length.
    Apr 2020
    tucson az
    you might try uhaul they carry all kinds of adapters and are able to order a variety of them if they dont have it in stock
    2011 rt , pearl white
    Oct 2015
    Lynden, WA
    Cut the flat four in half and Tape/Glue it back together in a square. Has worked for me for several years...
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    May 2017
    Fort Collins, Co
    when I got my trailer in 2017 from Mini trailer usa in okahoma I got a made adapter for it from them. they used to be a sponser here. Might give them a call.
Tags for this Thread
