Results 1 to 17 of 17
    Active Member Realtor's Avatar
    Nov 2018
    Pensacola
    Default 2015 RTS - Fender lights not flashing - HELP!!!!
    Scenario:
    why will my right fender running lights/signals not blink? While using the right signal, all other lights blink and flash, however the flash is faster that normal. (like a bulb is bad, but they're all good..)
    They operate like they always have except they aren't flashing. When I turn the key on, they light up in the running light mode, but when I try and turn on the right hand flashers, the fender lights remain lit and no flashing....
    I've taken apart and cleaned/reseated the connections, I still have the same results. Left side works fine, just the right side turn signal fails to flash the fender led's.
    Any ideas?
    Thanks, Jim
    Jim Summers - Pensacola FL
    www.PensacolaHouseHunters.com
    2018 RT , Blue
    Quote Originally Posted by Realtor View Post
    Scenario:
    Any ideas?
    Thanks, Jim
    If your talking about ....OEM fender lights .... I don't think they ever did .... If you have after market contact the seller .....good luck .... Mike
    indpls in
    sounds like a broken wire
    Nov 2018
    Pensacola
    this might help....
    https://youtu.be/C2RVEvrRs3k
    2018 RT , Blue
    Nov 2018
    Pensacola
    they flashed on Sunday, they were on the bike when I bought it.
    2018 RT , Blue
    Mar 2008
    Hesston, PA
    If they are the aftermarket kits that make them blink alternatery with the turn signals??? I think there is a flasher module for each side, if my memory service me correctly...larryd
    Nov 2018
    Pensacola
    Quote Originally Posted by larryd View Post
    there is a little in line computer board looking thing, I cleaned it, resealed it up and same result. I checked with a voltmeter, there's power going through it. I guess the flashing part of that could be bad?
    2018 RT , Blue
    Nov 2015
    Chardon, OH
    this might help....
    It helps. Those are an after market item. Looks like these.
    https://www.slingmods.com/canam-spyd...lights-tricled
    You could contact TricLED for assistance with troubleshooting and replacement parts. They’re the manufacturer. Good people. They’re always glad to help.
    Doug
    ”Freedom is not a loophole”
    Nov 2018
    Pensacola
    I called TricLED, they weren't much help, what I described, they didn't make... Just sent pics and video to custom dynamics, It's theirs, and They are sending me a replacement. the module is the issue...
    2018 RT , Blue
    Bossier LoUiSiAna
    Had similar issue & connection broke where was tapped into behind mirror. Unfortunately one of last places checked.
    Kind of like why do you always find a lost item in the last place you look?
    INDIANA, USA
    Default Lost and Found
    That's the way life goes sometimes. Lost for a period of time and then you finally find it.
    Stay Healthy. ....
    ENJOY YOUR LIFE WITH A SPYDER
    Bossier LoUiSiAna
    Quote Originally Posted by Little Blue View Post
    Stay Healthy. ....
    Better that than not finding at all
    Nov 2018
    Pensacola
    2 Thumbs up to Custom Dynamics for the replacement part to make the lights blink again. I'll be buying more things from them, very easy to work with and very good about standing behind their products. Thought you'd like a little feedback. I'll get it on the bike asap..
    2018 RT , Blue
    Active Member 3Tyme's Avatar
    Feb 2019
    SE Ohio
    Do you keep looking after you find it?
    2015 F3-S , Silver
    Quote Originally Posted by 3Tyme View Post
    Only when I forget that I already found it! Oh, the joys of getting old.
    Active Member sledge's Avatar
    Aug 2021
    Limestone Tn.
    ohhhhhhhh my Yes , back when I was still working everyday , I thought many times about hiking through the mountains behind my house after I retired now... I can bearly get out of bed , and a big job just washing my Spyder for a sunny day ride , I never knew any of this . . . it's not just like I always planned it really...
    2011 RTS Spyder
