Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
  1. #26
    Feb 2020
    Minnesota,USA
    It will be interesting to see how these asymmetrics go……just installed yesterday…… 165/60
    https://www.goodyear.com.au/tyres/go...agrip-529521-p
    Pete, I believe you made a good choice with the 165/60R15. I've got the 175/55R15 on my RTL and they have a very close tolerance of tire to fender. With your slightly poorer road conditions down under you need a little more clearance for
    road debris. Good Year Tires have always been a top seller in our area. I would not hesitate to put them on my ride.
    Good Luck Bill
    If in Doubt, Don't Do It!
  2. #27
    Harrington, Australia
    Quote Originally Posted by Isopedella View Post
    Ha. How about a non directional tyre to add to the mix?
    These are available here in NZ and I popped them on my Spyder and they fit without problems with clearance.
    Preform exceedingly well in my opinion.
    Yeah, I had them on my F3-L, Isopedella. They were fantastic. But they only appear to be bringing the 175/60 into Aus these days
    HeliBars Handlebars
    Kenda Kanine rear.
  3. #28
    Feb 2022
    New Zealand
    Music to my ears. I guess I just got lucky there as I really just took a punt.
    I have ridden in every type of surface here locally here cept snow and I am very happy.
  4. #29
    You’ll hear some Americans claim the Kuhmo are ordinary in the wet, but Peter A (who runs Kuhmo on his) and I, along with quite a few others, have not had an issue out here. We must have a different road compound perhaps. I imagine UnZud would probably use a similar compound to us.
    HeliBars Handlebars
    Kenda Kanine rear.
  5. #30
    Here is an interesting, non-scientific, customer rating of a good number of tires. When you priortitize what you're looking for and discount things like snow traction. A few tires in our sizes do rise near the top.
    https://www.tirerack.com/tires/surve...&type=GTAS&VT=
    Going back to this link I see it was not rendering the way I wanted it to. You will need to click on the 'Select Tire Size' option, then select 'Shop by Size' in the next screen. Sounds complicated. But it's very easy and will give you some good information.
    Possible tire sizes for the Spyder are;
    Front.
    165/60R15 - OEM Size
    175/55R15 - Slightly wider and slightly shorter than OEM
    Rear.
    225/50R15 - OEM Size
    215/60R15 - Slightly narrower and taller than OEM.
    205/60R15 - Slightly narrower than the 215/60R15. Taller than OEM, but less than the 215/60R15
    205/65R15 - Same width as the 205/60R15. Slightly taller than the 215/60R15
  6. #31
    Jan 2021
    northeast pa.
    https://www.tirerack.com/tires/surve....jsp?type=GTAS
    thanks for all info,, everyone says these will fit with no issues, so i am going with these,,
    https://www.tirerack.com/tires/tires...R5QT&tab=Sizes
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
  7. #32
    Quote Originally Posted by fredgal View Post
    We have installed quite a few of these on customers Spyders. So far, they are all very impressed. Be sure your alignment is good. But this is true of any vehicle you're putting new tires on.
  8. #33
    The issue with this chart is ..... not many of these tires will fit any Spyders...... I did notice that the Vredestein brand are near the top of that list and I think all of them will fit ...... I checked the bottom also I noticed how many tires made by Hankook are there ...... Mike
  9. #34
    Mar 2015
    Tacoma WA.
    We have the fronts..what's a good rear tire? Approaching 20k on my tryke and I'm thinking of a tire change..
    2017 F3-S Daytona , Yellow and black
  10. #35
    Mar 2015
    Tacoma WA.
    There is nothing wrong with the tread pattern or rubber compound on the OEM tires. If the tire is round (which they often are not) they will run fine. At highway speeds, you only have about 3" of contact patch at the rear wheel because the OEM tire is built too weak to hold shape and balloons out in the middle. Harder to hydroplane on that narrow a surface. With a car tire, you're going to get 100% tire width contact all the time. So, more important to get a wet capable tire.
    Just curious, who do you get to install the new tires on the rim, with balancing?
  11. #36
    Quote Originally Posted by TerryTheSpyderRyder View Post
    I've been here since 2010 (2011 as a member) ..... IF you are using Auto tires don't bother balancing the REAR tire, they don't need it to work properly.... the fronts should be able to be spin balanced to correct any issues ..... Mike
  12. #37
    Feb 2022
    New Zealand
    I got mine fitted and balanced when I took the rims into a tyre shop. Where naturally they used a spin machine.
    For my "normal motorcycle tyres. I fit them at home and use a Static Balancer.
  13. #38
    Feb 2022
    New Zealand
    Cant agree with that advice at all. All the tyres are " car tyres" aren't they ?????????????.
    In my opinion a balanced wheel assembly preforms best. Compared to one that has a tyre just biffed on. Vibration is at a minimum. Also if there is a problem with a rim not straight or true its picked up on the balance. Smoother spinning results in more consistent contact path available contact with the tyre and road surface.
    Like many I too am a qualified vehicle crash investigator.
    Gotta be preferable for a balanced wheel assembly I reckon. Front / rear dosnt matter.
    Please enlighten me as why not to bother.
  14. #39
    Aug 2019
    Stoughton, WI
    If you're in a shop getting your rear tire changed, why not spend the few $ to have the tire balanced? Peace of mind? Maybe, but it certainly won't hurt, and it might just help..
    2022 RT Sea To Sky
  15. #40
    Feb 2012
    Spring City,Utah
    Because many tire shops are not equiped to handle a Spyder rear rim.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  16. #41
    Feb 2023
    South Georgia USA
    Having run many miles on both the Quatrac and Quatrac 5 on the back and Quatrac 5's on the front I can say without a doubt they work well in the rain. And we get plenty of opportunities to try them out here in Mississippi.
    Hy Edmat, I think your trailer is one Hip deal
    Hank
    Last edited by HanklovesJesus; 02-13-2023 at 12:09 PM. Reason: forgot to identify who I was talking to
  17. #42
    I’ll let Mike answer formally, but just as an aside, the Kenda “Special Motorcycle Use Only” tyre is quite poorly made and usually requires a fair amount of balancing, Iso. On the other hand, the quality aftermarket car tyres that we put on Spyders not so much. I believe Mike is saying that “yes, get your rear tyre balanced if possible, but don’t fret if your tyre shop can’t do it, as it will be very close as long long as they have oriented the dot and valve stem correctly”.
    I had zero issues with the two rear aftermarkets I have used, which my tyre shop could not balance at the time…….and they can now, as they invested in the cones etc that allow them to fit the front and rear Spyder wheels with no damage. So I will indeed be having future front and rear assemblies balanced at the shop, just for piece of mind.
    HeliBars Handlebars
    Kenda Kanine rear.
  18. #43
    For all intents & purposes, OEM Kenda's are car/auto tires..... However, can you name what car/auto they can be used on ????? .... "ENLIGHTEN Me" - I'll try; the physical design and construction of the Spyder's rear suspension (not Ryker) is such that it would take a HUGE amount of "out of balance" to be felt by you or anyone else. ...... If you rode 10 identical Spyders and only one had the Rear wheel balanced I'd bet a lot of $ that you couldn't pick it out ...... Mike
  19. #44
    Feb 2022
    New Zealand
    Fitted and balanced is good advice.
    Waste of time the rest of it. Better things to do.
