Results 1 to 20 of 20
    Dec 2021
    Queensland
    Default OK genius's - What is this and where does it go?
    Whats this??????????
    And better still????
    Where do they both Go
    Mar 2011
    Pence, wi.
    The frunk liner
    2022 Spyder RTL- Chrome , Larger brake pedal Deep Marsala Red
    Dec 2021
    Queensland
    Quote Originally Posted by rhino1 View Post
    The frunk liner
    But where do they go??????
    I dunno that it is the Frunk Liner (which goes inside the Frunk, ie, under the lid at the front of your Spyder & forms the box that you put things in - FRont trUNK = FRUNK) but it's pretty hard to see the detail on my small screen with glare in those pics?! Any chance you take & post pics with better detail contrast that didn't have the camera aimed at a window/bright light like that??
    Mar 2017
    Salisbury,NC
    the spyder is not listed, but are these the heat shield upgrade for 2014?
    Quote Originally Posted by Kooler2 View Post
    Interesting .... did you find it laying on a road somewhere ????? .....
    Bossier LoUiSiAna
    Agreed hard to make out from pics. Couple questions: is that a pair of parts a L & R or just 1 part flipped around? How did you come across if not from your spyder? Your previous post mention a 2011RT correct?
    Maybe can look here https://can-am-shop.brp.com/on-road/..._ONR_EN_US_USD
    Dec 2021
    Queensland
    They both are from MY CanAm Spyder RT
    And what Glare?
    And what Glare?
    There's a glare or white haze emanating from the window behind the table/bench/whatever those things are sitting on, and in all of my (tiny, small, & small-ish) screens, that glare/bright light wipes out all the detail of whatever the black objects sitting on the table might be.
    It might be better if you stand between the light from the window and the table/whatever they're sitting on, then use a flash to highlight & fill in the detail of the objects; or maybe just point the camera at them from the side; but at the very least, don't point the camera directly at the window during daylight hours like it appears to be in those pics; but with them back-lit by a bright light as they are, leaving them pretty much completely washed out in glare & haze to the extent that I (& probably at least some others??) can't tell too much about them apart from their general outline & that they're coloured black, there's not much detail that I can see apart from them having an opening at each end forming a sort of tube or tunnel and there's a couple of holes in one side of the tube/tunnel bit!!
    Sebring, FL
    Background information and picture detail helps.
    Nov 2015
    Chardon, OH
    Looking back through your posts, it appears that you are rebuilding / repairing the front of a 2011 RT. If you have two of them, they look like the intake ducts on either side of the nose of your RT. That tunnel on the right and left side that ports airflow to your radiator and oil cooler.
    P.S. Use your phone camera and take pictures before and as you take stuff apart, to help in putting it back together.
    Doug
    ”Freedom is not a loophole”
    Dec 2021
    Queensland
    Thankyou so much
    Feb 2012
    Spring City,Utah
    Are you thinking #s 17 and 18 in the parts fiche? That's what they look like to me. The window glare in #1 and the light bouncing off the counter top in #2 make it hard to tell details.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Harrington, Australia
    And what Glare?
    That’s a bit agro toward people who are trying to help you based on zero background (not even a year and model) and poor photos, Kooler. Looks like Snowbelt has found the answer for you after doing some research himself on which model you are working on and what you are doing on it. Great effort, Snowbelt
    HeliBars Handlebars
    Kenda Kanine rear.
    Vermont
    https://can-am-shop.brp.com/on-road/...401/36Y1401b/y
    I am thinking it might be part of the saddle bags left and right side. The pictures have 2 holes for screws or push pins, grommets.
    Look at the bottom left hand side( it shows the back of the spyder, it shows the truck lid.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Dec 2021
    Queensland
    OK
    I never seen any Glare
    But if I you see it as agro
    SO BE IT
    Nov 2013
    Central Texas
    OK, one would think that if they came off of his Spyder, he would know what they are. Or maybe not.
    Sep 2021
    FL
    It would be different for the before 2013 and after 2013 model, but this is what it looks like on a 2018 when the frunk is completely removed.
    Last edited by Peter Aawen; 01-26-2023 at 04:09 PM. Reason: Fixed attach display ;-)
    Jun 2021
    Dunsford Ontario
    I don’t see any glare. I’d put them in the spare parts bin. If you removed them you should know where they go.
    2019 F3 Limited Pearl White
    Vermont
    What year is your spyder?
    What model is your spder( RT, F3,Ryker)?
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
