Results 1 to 10 of 10
    Mar 2018
    Florida
    Default Any ideas on what's causing this 2022 F3 vibration?
    At over 70 and at around 3900 RPM I get an occasional vibration that feels like a rough road rather than a wheel balance issue. It's not constant but comes and goes. Any ideas ? Is that what it fees like if you need a belt tensioner?
    Last edited by Peter Aawen; 01-23-2023 at 12:58 PM. Reason: Expanded title to briefly ask the question... ;-)
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by locomotion40 View Post
    Is yours equipped witha factory belt dampener? If not, they’re not expensive.
    2019 F3L , Covid Blue
    It's interesting that you mention " rough road ". It's rarely talked about here in connection to viberation.... however IMHO " rough roads " are more likely " road TEXTURE " issues .... ie. - what the surface composition consists of .... When you encounter this vibration make note of the actual surface at the time .... if / when the vibration goes away see if the surface changed ...... that may be the cause ...... Mike ..... If you think that vibration is a problem or just annoying ......Imagine how you will feel if the tensioner wheel FAILS ( and they have )and you trash your drive belt ( this has also happened !!!!! .... Plus do you think this is going to occur in your garage ????? .... Sometimes fixing very, very minor issues can have Catastrophic consequences..... I had some belt vibes ...I lowered the belt tension and now I can't feel them .... good luck .....Mike
    Aug 2013
    SF Bay Area
    Yes it sounds like you need the belt tensioner. The best is the BRP version but with LaMonster bearing and wheel. Check Spyderpops or LaMonsterGarage. Easy install. YouTube videos.
    2021 F3 Ltd , Magna Red
    Feb 2020
    Ontario, Canada
    I suggest to check belt tension (use the Krikit II belt tension gauge), if your belt is too loose the addition of the belt tensioner may not correct the vibration. I then added the Lamonster belt tensioner to both Spyders, which corrected the vibrations we were getting. Hope this helps.
    Also take a look at the front pulley CanAm has a recall on them, check your VIN against the recall listing
    2020 RT , Lamonster Brake Pedal Riser Petrol Metallic
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by cdavis6 View Post
    I agree. Before adding a belt dampener, check belt tension. (the tensioners are at the back of the axle. A belt dampener adds almost no belt tension). Then, if you still get annoying belt vibration, (which I think is most likely your issue. You will feel it most in your left foot peg). Then look into a QUALITY belt dampener. It doesn't pay to cut corners on this item as if it goes bad, it will quickly take your belt with it.
    Mar 2018
    Florida
    Default 2022 F3 Limited occasional vibration at 75 mph
    A local Spyder mechanic said my 2022 F3 Limited already has a factory installed belt tensioner. Is he correct? Also is a 2022 F3 like mine included in the front sprocket recall?
    Oct 2021
    Wichita, KS
    Yes
    No.
    Peter Pan has struck again!
    Member Darkside's Avatar
    Feb 2022
    FL
    I have the same vibration and it is not the road.
    2022 F3L (If it will ever come in)
    Active Member SkipH's Avatar
    Nov 2021
    Nevada
    I had similar vibration and it was the front Kenda stock tires out of round.
    Adj removable backrest, KOTT radiator screens
    Double horn (118db), Lamonster mirror fix
    tender plug in, luggage liner/bags, FOBO 2
    Drinks2go cup holder, replaced the seat strut
    Garmin DriveSmart 71 GPS, Garmin BC 30 backup camera.
    White pulley, Pedal Commander
    Laminar Lip- looks fonky but works.
    J&M 2003 CB installed
    Home made belt guard
    7x12 enclosed trailer
    2021 RTL Dark Chalk Metallic
    Skip H.
