Any ideas on where to put a better antenna for CB Radio?
I have a 2018 RT Ltd and I am looking at getting a midland 75-822 CB radio. Any ideas on where to put a better antenna?
Reason: Expanded title to briefly ask the question... ;-)
I found this one gives me a better signal. https://www.amazon.com/gp/aw/d/B07PF...b_b_asin_title
I’ve seen one clamped to a passenger hand rail.
I’ve thought about a magnetic one on a trunk rack.
Not sure if you could use a Goldwing antenna but it requires mounting to the side of the trunk. Drilling two big holes in it.
As a semi-retired truck driver, I liked to use Francis antennas which are inexpensive and available at any truck stop. The longer the better, but it catches more wind.Mounting it might take more ingenuity.
Thanks, I
I'll see where I can mount it. Any thoughts?
Do you have a luggage rack on the trunk? That would probably be my 1st choice. I don't know about you, but I cringe at drilling holes in my ryde.
Coke
If you are not real concerned with the look, I mounted a Firestick antenna on the front upper A arm on my 2019 F3L with the quick disconnect base. I used a stainless steel pipe clamp with a rubber insert in it from Amazon, and I only put the antenna on when I was taking a trip, otherwise around town it was off the bike.
https://www.amazon.com/LOKMAN-Stainl...417494871&th=1
