Results 1 to 23 of 23
    Dec 2022
    Florida
    Default And that's why I don't trust manufacturers recommendations!
    A lesson I learned on 32years as a technician is don't trust manufacturers maintenance intervals for their products. Do you really believe they care about your purchase? Do you really believe they make the better oil for you bike or car? The reality is, as soon you get out of the dealer they don't even want to honor the warranty and you trust this (**) mfg? My Can Am X3 RR's fluids were changed at 100 miles, front diff, gearbox, and engine oil - scared the heck of me when I saw the first 3 seconds of draining oil was pure grey oil! I changed it 3 times before their recommended 1000k. This Spyder oil is from 1059 mile; there's a lot of metal in the magnet and brass in the filter. I don't want that in my engine for 3k. I prefer to make 2 oil changes in that period. Also, BRP oil foams like crazy just by draining it, I can't imagine what it'd be like when it hit the crankshaft at 7000rpm. Amsoil is what my money buys.
    Last edited by Peter Aawen; 01-11-2023 at 09:53 PM. Reason: Caps/;,'s & reference changed to non-expletive reference.
    Dec 2015
    Oakley Utah
    I'll trust the manufacturers' engineers' recommendations.
    2014 RTL Platinum
    Mar 2015
    Fritch, Tx
    Hope you are not trusting the engineers who designed the cosmetics; like the black hole trunks on the pre-2020 models. If they are the same ones who wrote the maintenance specs they should not be allowed to reproduce. Our society is getting dumb enough on its own.
    Those who say " I can't" will always be right.
    Dec 2022
    Florida
    The same engineers who wrote the manual... one part says 5 qt; in another it says 5.5
    qt. They can't even write a manual correctly!
    Mar 2017
    Salisbury,NC
    just wait till you read more AND understand what is factual and what is not. these manual's have been copied from different models and years. you have to figure out what applies to YOUR model!!!
    Dec 2015
    Oakley Utah
    Quote Originally Posted by mandytuning View Post
    Engineers don't write manuals. That's done by technical writers.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Quote Originally Posted by cruisinTX View Post
    The mechanical engineers don't design body parts. That's done by design engineers. They don't design the production line either. Or the containers used to ship Spyders in.
    In fact, the engine is designed by Rotax engineers (not Can-Am), the electronics by Bosch engineers, the brakes by Brembo, etc.
    So, which engineers in particular don't you trust?
    2014 RTL Platinum
    The BRP personnel who write the manuals, whatever they call them, do an atrocious job.
    Sep 2016
    Chillicothe, Oh.
    I doubt that BRP writes anything. Like most other parts the manual is outsourced to the lowest bidder for reproduction and much is lost in the translation.
    2015 RT , Black
    Mar 2015
    Fritch, Tx
    none of them
    Dec 2015
    Oakley Utah
    none of them
    I trust engineers; modern society wouldn't exist without engineers and the faith we place in them. It's the C-suite, marketers and salespeople I don't trust.
    2014 RTL Platinum
    Active Member teninospyder's Avatar
    Sep 2014
    tenino, wa
    It is STILL a BRP responsibilty to have accurate documents out to the public - especially their customers.
    So............where are the proof readers ???????????????
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Sep 2014
    tenino, wa
    The quality of which we all see is openly questionable.
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Active Member Grayfox's Avatar
    Nov 2012
    Advance n. c.
    Amsoil for my 2012 rt
    May 2013
    Apex, N.C.
    I use whatever the manufacturer says, and change it as often as they say, as long as it is under warranty. Once the warranty is gone, I typically use the best that I can find. I don't want to give the manufacturer any reason to say that anything that I did caused it to void the warranty. In fact, If I have a good service department (which I fortunately do), I use them for all service while it is under warranty.
    Feb 2016
    Without having a proper oil analysis performed by a competent lab, you have no way of knowing what is actually going on inside ANY engine. You should have that oil analyzed to see what that metal is and where it came from. You could have bigger problems than brand of oil.
    2020 RT Limited , Marsala Red
    Jan 2019
    Hunter Valley NSW Australia
    I trust them - mine came with 3 years warranty and the amount of money that had to be spent by BRP on replacement bits during that time was money I didn't have to pay.
    I've got a '17 RTL - it's almost 3000km past the 75000 km service interval (I can't stay off the thing for 4 weeks while I wait for the booking date to come around) and my oil looks just fine. Are you sure you don't have another issue?
    I also concur with Jetfixer - we have an industrial lab for lubricants here in my area and its impressive wat they can tell you about what is going on inside a engine/compressor/gearbox/hydraulic system.
    2017 RTL
    2017 RTL , White
    What machine is the filter picture from? It doesn't look like a Spyder filter. How hot was the oil when you drained it? Hot oil will bubble like that.
    Oct 2021
    Wichita, KS
    I agree Pete.
    Peter Pan has struck again!
    Feb 2012
    Spring City,Utah
    Idaho, I think it is from a 1330. If you look at the second picture it shows "Rotax" on the side of the engine and from the openness of the engine I would say F3
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Dec 2022
    Florida
    I dont say oil cause the particles,what i mean is i dont want all the break-in particles running in my engine for so long, oil is cheap peace of mind.and yea, low quality hot oil makes foaming, not my amsoil.
    Active Member Woodenfish's Avatar
    Feb 2022
    Illinois
    Well you at least have to hand it to the engineer who designed the oil filtration.
    2021 Spyder RT Limited Asphalt Gray Chrome Edition
    2022 Spyder RT Limited Hyper Silver Chrome Edition
    Spyderco Paramilitary 2
    Vanquest Gen 2 7x10 First Aid Trauma Pack
    Garage Door Opener
    iPass
    DJI Action 2
    Tackform Anti-Vibe Phone Cradle
    UltraGard Full Covers
    Show Chrome rear trunk lid lift strut
    Noco Genius 1
    Noco GBX Booster X
    Show Chrome Platinum Grande Adjustable Padded Driver Backrest with Storage Pouch
    Baseus Cordless Inflator
    Sep 2018
    Australia
    Quote Originally Posted by Woodenfish View Post
    Unless K@N now supply the new ''Chunkomicron'' range of filters to BRP.hidesbehindsofa.gif
