Results 1 to 9 of 9
    Oct 2011
    Kalamazoo, Mi
    Default Looking for place to mount a digital volt meter on 2021 RT
    I have a digital voltmeter, https://www.amazon.com/dp/B0B1DTS5L5...roduct_details. Would appreciate others ideas, with pictures if possible on where you have mounted a voltmeter on your 2020 or newer RT's.
    Al in Kazoo
    2018 F3-T
    2018 F3-T , Pearl White
    Aug 2013
    SF Bay Area
    On my ‘21 F3 I have a Cell phone/GPS docking station that mounts to the center of the bars and comes with a choice of power USB/Cig ports. I replaced one with a USB/USB C/Volt meter. Not sure about the RT. I thought if there was an individual port version?
    2021 F3 Ltd , Magna Red
    Nov 2013
    Central Texas
    I put my combination double usb/voltmeter in the right speaker grill. I wired it directly to the battery, both hot and ground. Very convenient when I have my phone in the TacForm phone mount say, when using Google Maps on my phone as it charges continuously. I removed the grill and used a spade bit to drill a hole in the grill and secured it with the locknut that came with it. Hardest part was running the wiring to the battery, but even with that it only took me about an hour and a half start to finish. The one that I got is no longer available on Amazon, but there are others. Good luck & here's a link.
    https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    Active Member USAF's Avatar
    Aug 2022
    NY
    I was considering this also on our 2022, They should have included this in the dashboard with the ability to scroll to it like most modern vehicles have today.
    2022 Spyder RTL
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    I have one of these mounted on the left hand of the handlebar. It has a dual function, one function is if nothing is plugged into it it shows the voltage of the bike and the other is if you have something plugged into the USB port it shows the voltage going to the USB item.
    https://www.amazon.com/BlueFire-Wate.../dp/B075D8C565
    2022 RT Limited , Silver w/ Black and Purple accents
    Aug 2013
    SF Bay Area
    Quote Originally Posted by Rick28 View Post
    I have a 2019 Mini and it doesn’t have any kind of volt meter in the dash menu. Nor does it have one anywhere else.
    Vermont
    Quote Originally Posted by IGETAROUND View Post
    Al in Kazoo
    Off topic, I have the same volt meter on my sled.
    Sorry I can help you with placing the volt meter on a 2020 and newer RT''s.
    Hope some one will chime in with pictures.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    Quote Originally Posted by oldguyinTX View Post
    I have this same one on my F3L and would like it for my RTL I am purchasing. Does anyone have pics of this one installed on 2020 or newer RTL?
    Love my Spyders
    2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
    2014 RTS Circuit Yellow purchased 3/2/2018
    2020 RTL Petrol Blue purchased 1/27/2023
    Girls on Spyders #3195
    No more 2 wheels
    2020 RTL , Lamonster floor board riser Petrol Blue
    Vermont
    Al in Kazoo
    Hi Al,
    ( off topic, I used the volt meter on my sled this past weekend, and it works well). I check the volt meter on my sled, it gives me good info.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
