Results 1 to 9 of 9
    Mar 2022
    Huntsville, Alabama
    Default What parts & oil needed for Changing oil in 2012 RTL semi-auto?
    Basically, I'm looking for a DIY oil change sticky or something like that. I'm not having much luck finding one.
    I have seen a good "how to" video on YouTube before, and I'm sure I can find it again.
    I'm looking for additional information, such as parts I will need, where to get them for a reasonable price, which motor oils are good, etc.
    I'm about to do it for the first time.
    Last edited by Peter Aawen; 03-20-2023 at 12:27 PM. Reason: Expanded title to briefly ask the question... ;-)
    2012 Blue Spyder RT Limited
    Because your Spyder runs the 998 V-Twin motor, you need to search back a fair bit to find the applicable threads, but they are there. Here's a post added in reply to a thread asking much the same question back in 2018 - I don't know if the vids still work, but the info is here, IF you go back far enough - after all, the V-Twins ended production back around 2015/16
    there are several. This took 30 seconds.
    And here's another thread with some handy pics:
    https://www.spyderlovers.com/forums/...t=Changing+oil
    Feb 2022
    New Zealand
    .... I don't know if the vids still work....
    They worked for me .
    Last edited by Peter Aawen; 03-20-2023 at 01:48 PM. Reason: Fixed quote display ;-)
    Mar 2022
    Huntsville, Alabama
    I thought I went back pretty far, but obviously not enough. Thanks.
    Bossier LoUiSiAna
    Nov 2013
    Central Texas
    Feb 2012
    Spring City,Utah
    Baja Ron. All the filters o rings and washers and oil you need in one fell swoop.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Durham,Maine
    x3
    2012 RTL , Pearl
    The first think you need to do is determine which HCM filter you have. It is almost assured you have the Extended filter. But there is still an outside chance you are still using the Original HCM filter. Measure the length of the HCM cap. It is attached to the finned portion of the transmission. If the cap is 7/8" long, then you have the original. If it is 1-3/8" long. You have the extended. You will need to get the correct filter or it will not work.
    If you need more information. Let me know.
    Ron (bajaron)
