Results 1 to 5 of 5
    Jun 2021
    Sydney Australia
    Default Would RT Floorboards fit on a Ryker?
    Been thinking about this, looking to swap out pegs for floorboards there is a style that kind of curves around the (RT) brake pedal. possibly called SRTFB?? Would RT floorboards fit on a Ryker?
    Last edited by Peter Aawen; 01-03-2023 at 07:54 AM. Reason: Expanded title to briefly ask the question... ;-)
    Active Member Bob L's Avatar
    Oct 2014
    Massachusetts
    Can't say on the RT floorboards, but there are several variations of floorboards available for the Ryker. I put these on my wife's Ryker. https://www.lamonstergarage.com/lamo...r-floorboards/
    Good luck!
    Bob
    Bob L.
    Worcester County Massachusetts
    www.rk-mass2.org
    Nov 2018
    Waynesboro, PA
    https://www.lamonstergarage.com/floorboards-ryker/ and if you see some you like click on them and look at the bottom of the page there is usually a video on how to install them.
    My Spyder
    2012 RTL , Brown
    Jun 2021
    Sydney Australia
    Thank you gentlemen. I have seen the LaMonster offerings. I may lean that way but I like the way the RT floorboards are made, there is less taper at the heel and seems larger more comfortable
    Dec 2022
    Florida - Wimauma
    I have the Slingmods floorboards. Added a larger brake pad and they do work well together.
