Results 1 to 25 of 28
    Active Member PJveetwin's Avatar
    Oct 2022
    Peoples Republic of Calif. Upper Mojave Desert
    Default Show Chrome Trunk Rack After Thoughts.
    Although was not really needed, I decided to purchase and instal myself the trunk rack on my 21 RTLT. Directions were easy to follow and installed without an issue. So I realize the added weight does not allow the lid to remain open on it's own, but what annoys me is the lid is now slightly twisted and the right front bracket that goes into a hole or pocket, now needs to be twisted a bit to the right for the lid to close. With the rack sitting on the lid while fitting, it seemed to be hitting all 4 mounting points equally, not sure what's going on here.
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    I just removed my trunk rack. Really is heavy and you are correct, won't let the lid stay open. The trunk lid is shot. I don't/won't the rack.
    2005 Roadtrek Chevy 210P
    2020 RT Limited-Chalk White SE6
    Oct 2022
    How did you deal with the holes? Not cheap to replace the lid!!!
    Jun 2018
    Pahrump NV
    This is what I used. My holes in the lid were 5/16". And the end result.
    Oct 2022
    Quote Originally Posted by Bangorbob View Post
    Good idea, I can live with that, and maybe reinstall only if going on a big trip and is needed.
    May 2013
    Apex, N.C.
    Thanks for this post. I was actually considering one for mine. But with only possibly needing it for one big trip, it is not worth it to me.
    Jun 2018
    Pahrump NV
    It isn't hard to install the rack IF needed. The trim panel thingees make it pretty easy on the eyes. Good luck.
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    WONDER WARTHOG was awesome in the old ZAP comics of the 70s!!!
    2014 RTL bought in 3/20 with only 6,000 mi.
    Came with Garmin 660
    Car tires in 5/20; Elka stage 2 front shocks in 10/21
    Active Member Jesster72's Avatar
    Oct 2021
    IL
    I put racks on my last three bikes (1 Kawi and 2 Victories). I seriously thought about putting one on the Spyder, still a little up in the air. Thank you Pjveetwin for the pic - easier to visualize how it would look.
    Not sure that with the bag configuration of the Spyder, along with the room in the frunk, if we would use it, as has been stated above.....
    2022 Sea to Sky
    Mar 2021
    Arizona high country
    put one on the F3 Limited and use it anytime we take a trip two-up. The lid on the F3 does not use the hydraulic openers so that is not a problem. We use it for our jackets if we are not wearing them, as the bags are full for two of us.
    Oct 2022
    We also love the Freak Brothers. Gilbert Shelton was the best!! My wife painted this on my 82 FXR I built some years back. Most people do not have a clue
    Active Member SkipH's Avatar
    Nov 2021
    Nevada
    The more I look at that trunk rack, the more I think that it is upside down or maybe it's these old eyes..
    Adj removable backrest, KOTT radiator screens
    Double horn (118db), Lamonster mirror fix
    tender plug in, luggage liner/bags, FOBO 2
    Drinks2go cup holder, replaced the seat strut
    Garmin DriveSmart 71 GPS, Garmin BC 30 backup camera.
    White pulley, Pedal Commander
    Laminar Lip- looks fonky but works.
    J&M 2003 CB installed
    Home made belt guard
    7x12 enclosed trailer
    2021 RTL Dark Chalk Metallic
    Skip H.
    Very Active Member vtrider's Avatar
    Jul 2008
    Cambridge, Vermont
    It looks like it might be installed backwards. This is how it shows it installed on Spyderpops page. I have a new 2023 RT S2S on order and was considering getting this rack.
    https://spyderpops.com/luggage-rack-...with-top-case/
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    I believe you are right
    2022 F3 Limited , Monolith Black / Dark
    Northern Kalifornia
    I installed the following trunk rack. Then I installed a second strut because it increased the weight of the trunk lid and it wouldn't stay open on its own. Works great, with no issues. The rack allows my wife and I to carry enough stuff for a weekend jaunt and even a 3-dayer without having to pull the trailer for more storage.
    https://www.amazon.com/Show-Chrome-A...72580697&psc=1
    Nov 2021
    Nevada
    I put a show chrome rack on my Honda 1800, One of the Goldwing accessories site had bigger washers to put in under the rack to keep the lid from cracking. You might consider looking or install larger washers with rubber washers underneath. If can find it in my old files I'll post where they are.
    https://wingstuff.com/products/36950-trunk-rack-kit
    But they are out of stock....
    Skip H.
    Northern Kalifornia
    That's a nice kit, too bad they're out of stock. Try doing a wider search. If no luck finding an in stock kit then you can put together almost all the same items at Ace Hardware for under $5. That's the route I went and 40k miles later my rack and trunk lid are still in good shape.
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    Sebring, FL
    Good idea on the 5/16 trim plugs, were they from Amazon? I installed the rack on my 20 RTL and now find I don't need it, but there it is if I don't.
    Oct 2022
    As per the pictures on spyderPops, you're right, it's reversed, but if you look closer, the picture is not like my 21 RT, the box is much bigger and flat. When I originally was fitting the rack on my box, my box is smaller and wider to the rear than the front, like the rack. By reversing it, it follows the lines on my box. Looked really dumb the other way. The other rack really looks square where mine is tapered. I don't think they are not the same rack. Also when reversed, the wider mounting holes fell right on the ridge section on my box and would not sit flat. Look at the picture with the tape. So in my opinion, 5/16" holes were too big, yeah, easier to lay out and allow for some slop........ It takes a 1/4" bolt, so I used a minimal clearance bit for a 1/4" Had no problem screwing the bolts in. Anyhow, still makes no difference with the extra weight on the lid and warping my lid a bit.
    2021 RT LT
    Jun 2018
    Pahrump NV
    I will have to admit that you need to experiment with the size of the holes that were drilled. I wound up using A/C vacuum plugs cus they are flexible and fit tight.
    Nov 2013
    Central Texas
    Quote Originally Posted by redrazor View Post
    The hog of steel. And don't forget his alter ego Philibert Desenex.
    Active Member RULINGCHAOS's Avatar
    Oct 2022
    Sikeston, Missouri
    I have the rack on my 2017 and it was installed by the previous owner. I suppose he did a good job installing it because it works great with no issues. The lid stays open... barely. But it does.
    2017 Spyder RTL
    Mods
    Baja Ron Swaybar
    Mesh Intake covers
    LED Skidplate
    LED Headlights and Foglights
    TricLED Dual Color LED A-Arm Running Light Strips with Blinker
    12V Cell Phone / GPS Docking Station with Dual USB Charge Ports
    Quick detatch backrest
    Show Chrome RT Trunk Rack
    Show Chrome Short Spiral Radio Antenna
    Custom Airbrushed paint with ghost flames
    Mar 2019
    NEBRASKA
    image9.jpeg Any additional weight of the trunk lid will overload the lift struts. Easy solution is the to add the prop that has been sold by Pierre and shown by NorwegianRT and elucidated by so many folks. image6.jpeg
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Nov 2013
    Central Texas
    Quote Originally Posted by PJveetwin View Post
