Results 1 to 12 of 12
    Active Member USAF's Avatar
    Aug 2022
    NY
    Default What's the Best horn upgrade for 2020+ RT?
    I want to upgrade the wimpy horn on our 2022 RTL, I cant believe they come with such a wimpy horn. but anyway, what is the best horn kits out there for the 2020 & up model RT ? Im not looking for an air horn style, Just a regular horn.
    2022 Spyder RTL
    Nov 2013
    Central Texas
    https://smile.amazon.com/Wolo-419-Ba...s%2C335&sr=8-3
    WOLO Bad Boy 419 is what I have on my 2017 RTS. Pretty darn loud @ 150db. Easy install for me, as I could easily get to the stock horn. Comes with the necessary relay and very good instructions. You will need a 20 amp inline fuse, you can get one at any auto parts store. I also needed an "L" bracket, which I happened to have. I wired it directly to the battery, I had the necessary wires (red & black, 16 gauge) and connectors etc. also available at an auto parts store, and fishing the wires from the horn to the battery was a little time consuming, but when all was said and done, still only took about an hour.
    There is also this one @ 150db.
    https://smile.amazon.com/Wolo-619-Bi...s%2C335&sr=8-5
    Best of luck!
    Feb 2017
    I installed these dual horns from Sling Mods on my wife's 2021 Sea to Sky. Installation is a bit tricky but worth the effort. https://www.slingmods.com/canam-spyd...s?search=horns
    2015 Spyder RT-S (Arion) and 2021 RTL Sea to Sky (charming wife)
    Active Member Navvet's Avatar
    Apr 2016
    NC
    We installed https://motohorn.com/product/motohorn/ and love it.
    We like a good, loud horn that get attention and this does the trick. It looks big, but blends in nicely with the bike.
    https://motohorn.com/gallery/can-am-spyder/
    2013 F6B
    2016 F3 Ltd
    2016 F3 LTD , Triple Black
    Jun 2016
    Harrington, Australia
    I’ve got the Wolo Bad Boy on my ‘21 RT. It’s plenty loud enough, fits in the same spot as the stock horn (comes with a custom bracket but it is tight to get at the mounting nuts), and most important of all, it simply uses the existing wiring and spade connectors as it is not an air horn per se. I’m very happy with it.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Oct 2021
    Wichita, KS
    Quote Originally Posted by Arion View Post
    Peter Pan has struck again!
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    I have the same horns for both the wife's Ryker and my Spyder. Installation on my Sypder was a bit harder but well worth it. They are definitely loud.
    2021 RT Base - Petrol Blue
    Aug 2022
    NY
    Quote Originally Posted by Quickdraw View Post
    I have these saved on my list. What % louder do you think these are over the stock one ?
    2022 Spyder RTL
    May 2021
    Upstate NY State
    Quote Originally Posted by Rick28 View Post
    It's been so long since I installed the horns but if I was to estimate from memory, the horns I installed from slingmods have to be at least 2.5 to 3 times louder. They are loud. In fact, a while back someone cut my wife off to get off the highway. I pulled up beside him while he was on the off-ramp and blasted my horn. It scared the bajesus out of him.
    Jun 2016
    That’s why I don’t want one that is too loud, and am more than happy with the Wolo QuickDraw. Knowing my luck the dual horns would cause the other driver to jump……right into my lane that I am occupying
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Aug 2019
    Stoughton, WI
    2022 RT Sea To Sky
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    Have someone with a 2001-2010 GoldWing blow their horn for you. You can find plenty on ebay.
    "Love 'em all.... Let GOD sort 'em out!"
    2021 RTL Dark Chalk Metallic with comfort seat
    1978 GL1000 w/'75 engine show bike
    1976 RD400c
