If you bought your Rally new the exhaust that comes on it is federal compliant and aftermarket suppliers usually don't make systems that are any More quiet. Go listen to a standard 900 and if it is quieter than yours you could swap the muffler over to yours. Good luck on your quest.
Reason: then (a point in time) - than (a comparison or joining preposition) ;-)
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
I'll second the comments from Pegasus1300.
The stock muffler noise level is affected by cruising at 7,000 RPMs (sometimes 8,000)
X's 3 .... sometimes after-market suppliers will offer a " quieting baffle " for their mufflers, however even that will be louder than OEM stock ..... Mike
I use that mod all the time. Highly recommended. As far as the neighbors are concerned if they are complaining about the noise of your stock exhaust I bet it's not the exhaust they don't like. Probably the fact there is a bike on the block just irks some of them. Seen it many times.
