Results 1 to 6 of 6
    Very Active Member rjinaz86323's Avatar
    Mar 2021
    Arizona high country
    Default What does the windshield bracket bolt onto? Will it hold a GPS?
    Does anyone know what the bracket bolts to. I am wondering if it would be secure enough to attach a bracket to the base to be used to hold a GPS. I would like to get my GPS up higher without mounting it on the bars.
    Thx
    Last edited by Peter Aawen; 12-10-2022 at 04:05 PM. Reason: Expanded Title to briefly ask the question ;-)
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
    Quote Originally Posted by rjinaz86323 View Post
    Thx
    It's attached to the windshield Motor .... The windshield and bracket both shake a little, so whatever is attached that will shake also ..... good luck .... Mike
    Mar 2021
    This is an F3. No windshield motor
    Yep, so it is /..... Mike
    Active Member Frostbyte's Avatar
    Nov 2019
    Florida
    I have a 2019 RTL and have my XT high mounted at the edge of the dash using Ram Mounts and one of these brackets. However, I don't know if the cross bracket will work on 20 and up rigs.
    https://spyderstore.com/index.php?ro...&product_id=51
    Knowledge is the accumulation and remembering data.
    Wisdom is the effective application of it.
    [img]https://www.spyderlovers.com/forums/maps/map.png?
    2019 Spyder RT Limited , 2" brake pedal riser with wide pedal Phoenix Orange
    Active Member Smokes's Avatar
    Jan 2017
    Melbourne, Australia
    I mount mine on a RAM mount, middle of handlebars. Very solid there, and can easily be adjusted out of the way of the instruments.
    Andrew
    Melbourne Australia
    2016 F3L Spyder
    Now, wash your hands
