Results 1 to 19 of 19
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    Default I did the Oil, trans filter, & fuel filter change on my Spyder!
    I completed all of these things yesterday and even though it took me most of the afternoon I know it was done right and I saved a few (probably quite a few) bucks. The hardest part of it was getting to the fuel filter. It is in a different place to access..! But I’m just stubborn enough to stay at it til it was done. I got the oil change kit and trans filter from BajaRon and fuel filter from Amazon.
    Do t need to worry about it for a while now ..!!
    Last edited by Peter Aawen; 12-07-2022 at 01:28 PM. Reason: Expanded Title to briefly mention its purpose.... ;-)
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Rivco dual flag holder
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Rivco brand footrest
    spydermanexhaust.com exhaust
    Good job! The first time is always slower.
    Jun 2022
    N.E. Fl
    Wait till ya tackle the spark plugs.....
    2016 F3-T , Blk/Rd
    Congratulations! And you probably did a better job that anyone else would. (We also sell the BRP fuel filters, by the way.) But what I want to caution in this regard is that we had a customer come in last month with a plastic fuel filter installed. He'd done the work himself and put less than 100 miles on the bike. The fuel filter looked like a pumpkin! It had swelled up quite a bit and frankly. I was surprised it had not burst. It was about ready to.
    The Spyder fuel system is under high pressure. You can't just use any fuel filter that fits. Be sure you have a fuel filter that can take this pressure. Otherwise, you're doing yourself no favors. The BRP filter is unnecessarily expensive. I'll give you that. And there may be less expensive options that will work just fine. But please, do not cut corners on this one.
    Jun 2017
    Texas
    I used a metal type made by Wix so I’ll keep an eye on it. Thanks for the information..!
    2016 RT-Ltd
    Bajaron swaybar
    brake modulator
    missing belt guard
    Baker air wings
    Jun 2017
    Texas
    Yeah, I’ve read that it’s a challenge for sure ..!!
    2016 RT-Ltd
    Bajaron swaybar
    brake modulator
    missing belt guard
    Baker air wings
    Quote Originally Posted by Dmetcalf View Post
    The Wix should be good to go. You don't have to use a BRP filter.
    Active Member Realtor's Avatar
    Nov 2018
    Pensacola
    how often is the trans filter and fuel filter supposed to be changed? I have an oil change kit, bit there's only one filter in it?
    Jim Summers - Pensacola FL
    www.PensacolaHouseHunters.com
    2018 RT , Blue
    Quote Originally Posted by Realtor View Post
    28K on the 1330 HCM filter. Same for the fuel filter. There is only 1 filter in the Oil Service Kit because of the extended HCM filter interval.
    INDIANA, USA
    Default Did you raise your Spyder?
    ...How high did you raise your Spyder?
    What equipment did you use?
    A jack and or ramps. Or something else.
    Any Tips would be appreciated if you could help us.
    Yes, I am looking to try doing my own service work in the future.
    Stay Healthy. ....
    ENJOY YOUR LIFE WITH A SPYDER
    Quote Originally Posted by Little Blue View Post
    Stay Healthy. ....
    Depends on what you have at hand. You can use a floor jack and jack stands. Ramps can also work.
    Mar 2015
    forrest above Reno, Nv
    Lightbulb Tips
    A few little tips for you:
    1. Magic mirrors.
    2. Hex head drain plugs .
    3. A few minutes with a Dremel tool to open the area around the drain plugs.
    4. Good lighting.
    Others will add more tips for sure.
    Lew L
    2014 RTS , Circuit Yellow
    Mar 2022
    AZ
    What is the Wix P/n for the fuel filter you used?
    Jun 2017
    Texas
    2016 RT-Ltd
    Bajaron swaybar
    brake modulator
    missing belt guard
    Baker air wings
    Jun 2017
    Texas
    Ramps to run the front wheels up on then a scissor type jack to lift the back up ( jacking up on the lower shock bracket). I chocked the front wheels on the ramp for safety.
    2016 RT-Ltd
    Bajaron swaybar
    brake modulator
    missing belt guard
    Baker air wings
    Jun 2015
    carmi il
    Does anyone know what the fuel pressure is at the fuel filter?
    Dec 2012
    Murphy, NC
    I get my metal fuel filters from Car Quest. The part # is 86095.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Houston
    Quote Originally Posted by 1989hawk View Post
    40 psi or so
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Be careful with that. Jacking on the rear shock bracket can bend the mounting bolt.
