Results 1 to 14 of 14
    Dec 2022
    Northwestern ontario
    Default Brp can’t/wont fix my Spyder! Any thoughts?
    Two summers ago I lost my cruise control. Waited for switchgear. Dealer changed it. No difference. Then got limp home mode. Check DPS and VSS on guage. Dealer changed VSM module. No difference. Dealer has a hard time getting through to BRP and they are not being helpful, just asking to check things my guy has already checked. Any thoughts out there? 2011 998 RTS with 65,000 km.
    Last edited by Peter Aawen; 12-04-2022 at 05:02 PM. Reason: Expanded Title to briefly ask the question ;-)
    Sep 2013
    Houston
    Quote Originally Posted by Summersnowmobile View Post
    If your mechanic is waiting for BRP to diagnose the bike remotely, you are at the wrong shop. Especially with an older bike. You need to find a mechanic that KNOWS the older Spyders and can diagnose on his own using service manuals and diagrams. No small order I know. But your bike will not get fixed using a mechanic that does not know how.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Dec 2015
    Oakley Utah
    This is an authized dealership with certified Spyder mechanic? It doesn't sound like it.
    2014 RTL Platinum
    Dec 2013
    If the dealer &/or techs are having this much trouble, then I'm not all that sure I'd be trusting them to have diagnosed the Cruise Control issue correctly in the first place.... Sure, it might be obvious that it's not working, but who decided it needed new switchgear to get it sorted?!? This juuust might be starting to sound like a broken record from me to some here, but I've got a V-Twin Spyder that's had similar issues & I've seen quite a few other like aged Spyders with similar issues that all sheeted home to juuust the ONE thing.... so I'd ask - how old is your Spyder's battery & how was it being maintained before all this started?? What about since it's been sitting & waiting for switchgear, has it been on a battery maintainer, or just sitting there?? Anyone checked &/or recharged/replaced the battery before trying to operate it again after all that waiting??
    These 998 V-Twins are all getting on a bit in age now, and even if it's had a battery replacement at some stage, they do tend to have a parasitic power loss over time, especially if it's been left just sitting; and even more especially if it hasn't had an active battery maintenance program during this sitting period, the battery could be telling you it's old, tired, dying, or all of the above - and possibly any/all of this has been masked if not hidden by a battery tender too!! Just some of the issues a low battery can result in on a V-Twin include things like Limp Home Mode; DPS issues/failures; VSS warnings, etc, etc, etc; and any of them in their turn could well mean that even tho you might happen to get your Spyder running, your Cruise Control still might not work..... :banhghead:
    So, has anyone checked to see how old the battery in your Spyder might be?? And regardless of its age, even if it IS brand new (did it get a full & proper charge before installation??) has anyone ever &/or recently done a proper load check on it, or at least used a multi-meter to check that it's even vaguely within the right ball park to let it work your Spyder and all the power hungry things like DPS & VSS that could be contributing if not actually causing all this??
    Just Sayin'
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Oct 2022
    Estonia
    Had the same issue. I bent the brake light switch bracket a bit and that fixed it
    2013 St-S , Yellow Metallic
    Jun 2016
    Harrington, Australia
    Quote Originally Posted by erks1 View Post
    Are you saying that the Spyder believed the brake was being applied and shut off Cruise Control, Erks ?
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Dec 2022
    The brake light works normally going off and on with the pedal. However, when hooked up to buds the computer is reading that the brake is on regardless of what’s happening with the brake light.
    May 2017
    Mesa, Arid-Zone-A
    I think you have just found the problem.....
    Semper Fi
    Dec 2022
    Yes. That’s the problem for sure. Trouble is we don’t know how to fix it��
    Check for crud on or in the brake actuator lever. Anything preventing the lever from full contact can cause the bike to not have cruise control (because the brakes are read as being on), or to go into limp mode.
    I had this issue with my 2008 GS and one of our friends who visited AK in 2010 had the "limp mode" issues. Riding the AK highway in unpaved places during the rain caused "glacial till" to coat the actuator. It caused a problem similar to riding with the foot on the brake, which will cause the actuator to seem as though the brakes are on. This will eventually kick in the limp mode. Actuator cleaned, problem solved.
    Dec 2022
    Did the brake light behave as normal even with the dirty actuator?
    Sep 2013
    Houston
    Now that the problem is known, you refer to the wiring diagrams and diagnose the circuit from the pedal swatch to the ECM to find where the problem is. You now know its in that circuit somewhere.
    Sep 2017
    Durham,Maine
    I seem to recall someone having something like this going on and that assembly having a twostep micro switch of some sort and having to clean it or replace it to make it work right!dontknow: good luck, I would dive into that switch assembly if it was me.
    2012 RTL , Pearl
    Oct 2022
    Estonia
    Yes. The cruise control switches off when braking. The signal word is the brake light. If the brake light is on, the cruise control does not work
