Results 1 to 5 of 5
    Very Active Member SNOOPY's Avatar
    Aug 2013
    Default How straightforward is an ST's Coolant change?
    Searched already
    Anyone know of a coolant change write up for a ST or is it pretty straight forward?
    I’ve read here not to try the drain plug because it can twist and break, disconnect the hose instead.
    Any other do’s and don’ts? Are there bleeders on the 998’s? Any fluid better than others or just go by the manual?
    Last edited by Peter Aawen; 11-24-2022 at 03:51 PM. Reason: Expanded Title to briefly ask a question ;-)
    Jun 2011
    Near Lexington, NC
    My memory fails me, but I think the 998 used a different coolant than 1330. Would think tho, that if you give the bike a good flush, you could use a long term fluid. I use Dex-cool for topping off as my dealer tec said that is, essentially, what BRP uses.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Aug 2007
    Greeneville, TN
    The drain plug is not necessarily a 'Don't'. We have found that some come off easily. And it is less work than pulling a hose. We apply PB Blaster, let it sit a bit and GENTLY turn. It's easy to know how much pressure is safely applied. Sometimes the plug comes right out and you're golden! If it doesn't, no harm. It's not like it will snap off in your hand with no warning. Applying reasonable pressure will not hurt anything.
    Otherwise, it's a pretty straight forward event. Fill the reservoir to the 'Cold' line and shake the Spyder. Rocking it back and forth helps dislodge air before you start. Put more coolant in if necessary to bring it back to the 'Cold' line.
    Let it idle at first so that any cavitation is not damaging. Get it to operating temperature watching coolant level. Top it off and go riding for a few miles. Come back and check coolant level again. You should be Good to Go!
    Happy Thanksgiving!
    Bossier LoUiSiAna
    Be sure to NOT mix colors of coolant. Flush/Rinse Thoroughly & repeat every 2 years.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Aug 2013
    Happy Thanksgiving!
    Thank you, so pretty straight forward.
