Results 1 to 14 of 14
    Nov 2022
    North Carolina
    Default Shifting Issues - F3 won't always shift out of 1st - anyone else?
    2018 F3 Limited 6,000 miles, just serviced ... So, I took my "new" F3 out for our first serious ride today. On three separate occasions after coming to a stop, it wouldn't shift out of 1st gear. After sitting beside the road fussin' and cussin' for a few minutes and several restarts it was fine until the next time it happened. Kind of feels like a heat/temp issue to me. Checked the oil and it is in normal range. Anyone else been through this?
    Last edited by Peter Aawen; 11-23-2022 at 03:43 PM. Reason: Expanded Title to briefly ask the question ;-)
    Feb 2022
    New Zealand
    Nov 2022
    North Carolina
    That's a little different than mine. I was able to get in neutral, then it wouldn't go into any gear for 10- 15 minutes. That's why heat/temp comes to mind. Modules/electronics can be bothered by heat or overheat themselves, I think. At least they used to back in my hot-rodding days. Will check for codes tomorrow.
    Happy Thanksgiving everyone!
    Quote Originally Posted by cjr00 View Post
    There have been quite a few reports of problems with the " paddle shifters ", so I think this is a possibility .....good luck ... Mike
    Jun 2011
    Near Lexington, NC
    Make sure your coolant is topped off. If it get very low, it plays heck with the sensors.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Very Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    Yes, this, there was a service recall for this very same problem affecting the 2018's.
    2018 RT LTD , Black
    Nov 2022
    North Carolina
    Update... service tech texted me. Replacement shifter switch has been ordered. No ETA, but it's progress!
    Feb 2022
    New Zealand
    Yup. Progress.
    Ta for the update.
    Active Member VitoNam's Avatar
    Nov 2018
    NW Minnesota
    This fall, the left hand control module (aka as the left hand -switch-) on my 2018 F3L (17K miles) had similar issues as yours. A call to my dealer about the problem resulted in BRP covering the replacement module under a "Good Will" warranty that covered parts and labor. This is a well documented problem. My Spyder is back to shifting as good as new. Thumbs up to BRP for the acknowledgement of the problem and taking care of me. The module alone is a $510 part.
    Nov 2022
    North Carolina
    Great info, great results, Thanks
    Nov 2022
    North Carolina
    Left hand switch replaced, no charge, bike picked up and ridden 4 hours over two days. Shifting beautifully. Come on sunshine, Daddy's ready to ride!
    2018 F3 Limited
    Netherlands
    Had the same on my 2020 F3S, not just poor shifting but also indicator button reacting on it's own will. Lefthand switch replaced under warranty and now it is back to how it should be
    2020 F3S , Matte black
    Member michaelalvis's Avatar
    Nov 2020
    Tennessee
    Default Stuck in Neutral
    In December, I got stranded on a hill along a narrow rural road on my new 2022 F3-S when coming to a stop. The Spyder was stuck in neutral and I couldn't change it into any gear (forward or reverse). To make matters worse, the parking brake wouldn't engage, so I could not dismount to investigate the problem. Fortunately, 2 "good Samaritans" stopped and helped me chock the rear tire and get the Spyder turned around and off the side of the narrow curvy road.
    I called BRP Roadside Assistance for a tow truck. I was out of their network, so I was instructed to call a local towing business that towed my new Spyder to the nearest dealer (where I purchased my Spyder). It was repaired under warranty at no cost. However, I am now trying to get BRP to reimburse me for the $124 towing charge because I had to pay out-of-pocket for the towing.
    I have attached a photo of the broken part that prevented me from shifting into any usable gear.
    Current:
    ~ 2020 Ryker 900 ACE
    ~ 2022 Spyder F3-S
    Previous bikes:
    2001 Triumph Thunderbird
    2002 Triumph Trophy 1200
    2005 Vespa GT200
    2010 Triumph Bonneville Black
    2018 Suzuki Burgman 400ABS
    2 & 3 wheel rides:
    Visited states:
    [img
    Nov 2018
    NW Minnesota
    Ah...the kindness of strangers. Nice to know that there are many folks out there who are willing to lend a hand!
