Results 1 to 7 of 7
    Nov 2022
    North Carolina
    Default Excessive Wind Buffeting on F3 - what height/width w/shield to fix?
    Well... Just purchased a 2018 F3 Limited /5800 miles. Very nice condition overall. When I get up to highway speeds the buffeting is unbearable. I'm 5'8" and wondering what height and width windshield I should have on this beauty. Would prefer going straight to a different windshield and not mess around with extensions etc. Saw a video of the Blue Ridge with a "flip" on top. Whataya think?
    Last edited by Peter Aawen; 11-18-2022 at 07:43 PM. Reason: Expanded Title to briefly ask the question ;-)
    Active Member johnv50's Avatar
    Jun 2018
    Tonawanda, NY
    I dealt with a company called 7Jurock, they specialize in the recurve at the top windshields.
    They have a selection of standard sizes and will also build one to your specifications.
    The also have very reasonable pricing. 7jurock.com
    johnv
    USMC RETIRED
    BLUE KNIGHTS NYV
    2022 F3T Glacier Blue
    Jun 2011
    Near Lexington, NC
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Quote Originally Posted by cjr00 View Post
    You're holding onto the handlebars too tightly. Keep your body and grip loose and go with the flow. You cannot comfortably fight the wind. You'll get it figured out in a few hundred miles!
    Feb 2022
    New Zealand
    Extensions are not for me. Tried some of those on other bikes then binned them, literally. I am 6 - 2 and went for the biggest F4 with winglets. Its Majic. Visor up riding all day no worries.
    SoFlo
    Pretty sure you can low cost try a fix. If you remove the upper windscreen fasteners, and place a couple of shim washers between the rubber grommet and windscreen mounting frame, tilting the windscreen a bit more vertical, it may be enough to deflect the airflow over your helmet, reducing buffeting.
    As a test, before making the change, at the speed you feel buffeting, slowly lower yourself to find a point where the buffeting is gone. If nothing else, that will provide an approximate amount of needed windscreen height if you buy a replacement.
    Myself, I would shim the windscreen first, simple, inexpensive, and very likely could work for most folks.
    Nov 2022
    North Carolina
    Genius! Will definitely give that a try. Thanks
