Results 1 to 14 of 14
    Oct 2022
    GA
    Default Another Fuel Door Install; 2014 Spyder RTS
    With the help of those of you who had performed this procedure before me, I installed a billet fuel door on my spyder over the last couple of days. And I took lots of pictures! So without further ado;
    This is the fuel door I used.
    The fuel door taken apart.
    The seat with tape showing the level line and center point of the gas cap and fuel door. Note the tape showing cap location and fairing start point.
    Another view of center point already punched with soldering iron.
    Bulls Eye!
    Hole in seat via the soldering iron with seat vinyl pulled back.
    Hole marked and ready to cut.
    I used a 4 1/2” hole saw and turned it by hand to cut the foam. Once the foam was removed, I used the hole saw to cut through the pan (plastic) by running it backwards.
    What the pan looks like after it’s cut.
    I pulled the vinyl back into place and marked the cut lines.
    I cut the vinyl using a utility knife and cut a piece of leather to line the exposed edge of foam.
    Then I pulled the tabs formed by cutting the vinyl back and temporarily stapled them on the back of the pan.
    What the front side of the seat looked like after pulling the vinyl back and stapling.
    The fuel door clamped into place and ready to punch the holes with the soldering iron.
    Hardware used; cut the prongs off the t-nuts using a pair of diagonal cutters, punch one hole, insert screw through the front and t-nut through the back. Tighten to hold fuel door in place.
    The t-nut on the high side of the pan will require a bit more trimming in order to ensure clearance when the seat is in the down position.
    Hardware installed.
    Hardware trimmed with a dremel tool and cutoff disc.
    High side t-nut trimmed to fit.
    Fuel door tightened down, vinyl tabs pulled tight and stapled into place.
    Back of seat covered with a piece of leather to protect the left side fairing.
    Spray adhesive and staples were used to secure the leather. Vinyl was pulled into place and stapled with stainless steel staples.
    Fuel door installed and closed.
    Fuel door open…. Note the piece of leather on the latch plate; keeps the door from rattling by tightening the latch and protects my hand from getting cut by the latch plate.
    Nice job Thyatt ..... I remember we had a few conversations about how to do this, I'm glad you got it done. ..... But to be honest to anyone else who wants to do this, I didn't do it this way...... When I was doing them as a Vendor my methods allowed me to accomplish it in about 45 minutes.... in a parking lot..... Yours did come out quite nice, and I'm glad ...... Mike
    Oct 2015
    Lynden, WA
    Looks very nice.
    Great bit of DIY.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Jun 2015
    Ritzville, Wa
    Great job. Looks like a professional install. Cool!
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Oct 2022
    GA
    Thanks Mike. I took inspiration from our conversations to move from concept to reality. It almost didn’t happen as the door was lost in the mail for a week or so, then the hardware was back ordered. I enjoyed doing this project; it’s more about the challenge and the thought process than anything else. I looked at all the door installs I could find and developed a pros and cons list, then determined the “best practices” from each. I took my time so I could enjoy the experience and bask in the glow of a job well done. Sometimes my OCD gets in the way…. I did learn that taking off the seat is not something I wish to do again anytime soon; I dropped two sockets and a wrench down under the seat frame. Then the seat wouldn’t line back up at hinge points. How an aluminum bushing becomes too long to fit an area it came from is beyond me…
    Member Michael5's Avatar
    Feb 2023
    MARYLAND
    Is there a specific door you should purchase?
    Quote Originally Posted by Michael5 View Post
    A fuel door will be hard to find today..... The ones from F- 150 & 250's work the best; Years '96 thru 2010 ..... I'll see if I can find one ..... later .... Mike ....
    PS read post #2 above ......... I can't do links, so go to E-bay and enter either of these item numbers .... # 124229953328 ... or # 125509909676 .... both are $37.20 - Delivered ..... PM me if you need help .... Mike
    Last edited by BLUEKNIGHT911; 02-04-2023 at 01:29 AM. Reason: Removed colour so all can read. ;-)
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    I've actually considered doing this, but was afraid it would burn my g/f's legs should it be her turn behind the handlebars.
    You guessed it: she's on the short side, lol.
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
    Quote Originally Posted by Peacekeeper6 View Post
    I put mine on in 2014 ...it's black .... even on days when the Temp has been over 100 F and sunny, I've never felt any heat .... I also Never wear shorts when riding the Spyder ... just reg. Jeans .... Mike
    Feb 2023
    MARYLAND
    Thanks for the info found one !
    Active Member SkipH's Avatar
    Nov 2021
    Nevada
    Question: Can it be open and closed without the key?
    Adj removable backrest, KOTT radiator screens
    Double horn (118db), Lamonster mirror fix
    tender plug in, luggage liner/bags, FOBO 2
    Drinks2go cup holder, replaced the seat strut
    Garmin DriveSmart 71 GPS, Garmin BC 30 backup camera.
    White pulley, Pedal Commander
    Laminar Lip- looks fonky but works.
    J&M 2003 CB installed
    Home made belt guard
    7x12 enclosed trailer
    2021 RTL Dark Chalk Metallic
    Skip H.
    Quote Originally Posted by SkipH View Post
    YES ... that's how mine works, and yours can too..... I haven't found one without a lock in years..... I did these as a vendor and got the install time down to about 45 minutes. .... I didn't take the seat off ... just propped it up ....I did un-do one end of the gas strut first..... find what the HOW TO that I did ....it will make it much easier .... Mike .... PS I posted two " Doors " in post # 7, I have used that model before. ....
    Feb 2023
    MARYLAND
    Thanks for the info was able to get it and installed !
    I don't know who you are thanking, but if it was me then Good for you ..... I hope you found my posts / threads on " how to ", helpful ......... Mike
