Looking at Changing panels on 2021 F3-S - Any help appreciated
Hello - I am interested in getting the metallic black paint exterior vs the current matt black and would like to order the 2022 F3 panels in metallic black to replace my matt black 2021 F3-S panels. I assuming they can be swapped out? It appears they are the same form, fit, and function and should work. I did ask the dealer and they are trying to find out as well.
The first part of the individual part numbers are the same.
Any help would be appreciated. Thank You
Reason: Expanded Title to briefly mention thread purpose.... ;-)
I checked into this last year. They will swap, but they don't come with the foam backing. You'll also need to pop off the forward gloss aux light piece.
2022 RT Sea To Sky
