Results 1 to 6 of 6
    Nov 2013
    Central Texas
    Default Front Sprocket Again - filed an NHTSA Complaint
    This is a complaint that I filed with NHTSA about the recall. It is somewhat long, but I hope other members on this forum will also file complaints. It can't hurt, and maybe light a fire under BRP's a** and compel them to be truthful for once.
    RE: NHTSA recall #22V352.
    BRP has not moved forward in a timely manner to remedy this issue. They continue to move the resolution date further out from the original date, and continue to blame a cyber attack on their computer systems that occurred on August 8, 2022 for their failure to supply the necessary parts to complete the repair under this recall. Additionally, they also blame a material shortage for their inability to supply the parts necessary to complete the repair. This is an issue that BRP has known about for at least 2 years, and did nothing about it. They did the same thing with the recall of 2013 RT's to remedy a heat issue, which caused a number of bikes to catch fire with no warning. This is typical behavior on the part of BRP. Ignore an issue, and it will go away. In my opinion, NHTSA should compel BRP to complete the repair under this recall immediately, or require BRP to make a truthful and compelling case as to why they cannot do so.
    Also, check the NHTSA website for Part 573 Safety Recall Report, Recall # 22V352 Note on page 2 that Transport Canada filed a report in May of 2021, and it seems that BRP really did not address it.
    Last edited by Peter Aawen; 11-04-2022 at 03:34 PM. Reason: OP - Additional Information; Then PA, Repot - Report ;-)
    May 2013
    Apex, N.C.
    It would be nice, but good luck. Dodge and Jeep (only speaking about them because of experience) have been having air bag issues since before the air bag in my 2002 Jeep Liberty blew up in my face. This was over 5 years ago. And to date they are still doing recalls. The best advice that they can give is "don't drive them". I feel your pain, as I have a 2016 that is under the pulley recall. But I doubt it works.
    Northern Kalifornia
    Fortunately for me, I don't have this sprocket issue. However, I've seen an array of sprockets for sale on the internet that look similar to the BRP sprocket in question. Has anyone looked into modifying a similar sprocket that could effectively work on the spyder?
    INDIANA, USA
    Default Still Waiting for my Front Sprocket
    Quote Originally Posted by oldguyinTX View Post
    I have done this process and I am still waiting for some real answers. Hopefully this will all turn out better very soon.
    Still Waiting......
    ENJOY YOUR LIFE WITH A SPYDER
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    While we're on this topic, has anyone ever filed a complaint with the NHTSA over the substandard Kenda tires?
    Quote Originally Posted by Fat Baxter View Post
    Well actually they are D.O.T. certified for the Spyder ( ONLY ). And even though they are " J" type ( ie auto ) tires, they arn't legal to use on any Auto. Kenda's are marginal but the low weight of the Spyders allows them to be used......JMHO .... Mike
