Results 1 to 6 of 6
Hybrid View
    Active Member USAF's Avatar
    Aug 2022
    NY
    Default 22 RTL how do I remove the panel below headlights?
    Hey guys, I was wondering how to remove the black lower panel under the headlights on my 22 RTL, I want to clean the bugs off that area and would be easier removed. I believe its the access panel to the coolant bottle is what I'm referring to.
    2022 Spyder RTL
    Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    Open your frunk to get to it. It easily pulls off and snaps back on.
    2021 RT Base - Petrol Blue
    Harrington, Australia
    Along with QuickDraws comment above, the panel has a small protrusion each side that sits under the body panel, Rick. You need to bend the panel out slightly to free one of the protrusions from one side, and it will pop out.
    HeliBars Handlebars
    Kenda Kanine rear.
    Aug 2022
    NY
    Thanks, I was concerned about the center between the headlights how it released, I didnt want to break anything.
    2022 Spyder RTL
    Aug 2018
    Santa Ana, Ca
    Default panel removal
    Is it on bottom or top of panel and do you lift up or to the side?
    Quote Originally Posted by Dean8 View Post
    Sorry Dean….I have just got up out here
    It protrudes slightly out each end. Grab the panel in the middle and pull toward you, while you push the side edge of the panel inwards. That should enable you to see the small protrusion and allow one side to pop out. I’d post a photo, but I’m not home at the moment.
    HeliBars Handlebars
    Kenda Kanine rear.
